Originally Posted by
Landbt15
Hi all, I tried doing a search but came up with few results for my problem/confusion. So I apologize if I missed where this was covered.
I followed fastblackmerc's HID bulb upgrade for the foglights (
https://www.mercurymarauder.net/foru...ad.php?t=71964), but I'm stumped when it comes to connecting the ballast to the factory harness.
The long and short of it:
For those who have used a modified H10 HID set in their Marauder... how did you connect your ballast to the factory harness?
I'd like to avoid splicing wires.
I'm completely dumbfounded that there's not just a simple ballast plug to H1 plug available (all they have online is ballast plug to pigtail terminals which don't fit).
Any help is appreciated!
The only product of this type that I have ever seen is made by Kensun and can be found in several configurations on Amazon. " Kensun Easy Install Relay Harness for HID Bi-Xenon Lights - 1 pair - 9007 (HB5) Bi-Xenon (Moveable Dual Beam)" is obviously the one for he 9007 headlight bulbs in our cars. I have a pair of these Kensun parts in my car and they are a handy thing to have when you are not using one of the harnesses that come in the usual HID kit. Mine are hooked up to a harness that Goldpanther made for me. He was selling them for a while, and I have one in my Crown Vic as well. Extremely well built, heavy gauge wire directly to the power distribution block.
You know, they make LED's now that will do the job and more or less plug right in. Sorry I can't give you any detail on what I did because I am away from home and my modified units are in my garage. And the beauty of LED's is - no ballast.
