Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Marauder Weight....How Much?
    Jan 2005
    Just South of Memphis, TN
    Question Marauder Weight....How Much?
    Had the opportunity to weigh my marauder today at the local scrap (recycle) dealer...He felt the scales were within 10 lbs plus or minus....
    with a full tank of gasoline she weighed in at 4,260 lbs..
    Lets see....19 gallons of gas weighs 190.50 lbs...
    so that get's her down to 4,069.50...
    although it's tough to run with an empty tank...
    and probably another 30 lbs of "stuff" in the trunk...
    anyway...I tought someone might find this interesting
    Everyone be careful out there...architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    Derby City, KY
    Holy Bathroom Scale Batman!
    Sooo, you either weigh zero or you were out of the car?
    Thanks for the 411.
    Mike.
    Mar 2006
    Maple Valley, WA
    I thought water weighed 10 lbs. per gallon....and gas is lighter and I thought that weighed about 6 lbs. per gallon...hmmmm
    Former owner of a 2004 DTR MM
    Quote Originally Posted by junior
    I thought gas weighed 6 lbs. per gallon....
    Yep...for round numbers:
    Gas is 6 lbs a gallon
    Water is 8 lbs a gallon
    Stout Beer is 10 lbs a gallon.....J/K
    Long Island, NY
    What he said gas is 6 lbs per gallon.^^^^
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Jan 2005
    Quote Originally Posted by MM2004
    Thanks for the 411.
    Mike.
    I was in the car I just jumped up off the seat when they weighed it...
    architect
    30% Window Tint
    Rear Spoiler
    Aug 2005
    Macclenny, Florida
    Thanks, this is something I wondered about, specially after being on the track at Sebring with those much lighter Mustangs, some who had about the same engine.
    ~Jim
    2004 Mercury Marauder SB
    Purgatory, FL
    In Rider 90's 1st video, Wesman's MM weighed 4280. I wonder what added 20lbs to his?
    (#6178 in black per FPIC)
    Rest In Peace:
    Paula Babineau 1/9/67-8/2/11
    Rex Weinbender
    Peter
    Aug 2005
    JUPITER
    4260 with a full tank of gas? Doesn't that seem a little light? I thought they were heavier. But that is good news!!
    2003 300A Black MM
    Ride it like a Ford.!!
    Sarasota, FL
    Doesn't Marty's car weight like 4600 cause of the dynamat and roll cage?
    I still think these cars do pretty well considering their weight.
    2003 Mercury Marauder - 300A (Born 9/02, Purchased 1/16/04)
    • 1 Coil Cut Off Front Springs & Rear Air Suspension Lowered
    • PIAA Xtreme White 9007's
    • Red Reflective "MARAUDER" Inserts
    • JLT Performance Intake
    • Accufab Throttle Body
    • SCT-1725 Tuned
    • Borla Mufflers
    Dec 2004
    plymouth, mn
    Quote Originally Posted by RoyLPita
    Canadian air
    More likely: push bar, skid plates, tranny cooler, camera, Kooks, hitch
    Less likely: QA1's, wheels, tires
    There are a lot of little things that change our cars weight. Mine is probably on the porky side with the Trilogy and hitch.
    jeremy
    For the interest in comparision, my Crown Vic weighs 3900lbs with a 1/4 tank of gas and an empty trunk.
    99 Crown Vic, 14.241 n/a, 12.947 @ 104.05 spray
    00GT Windsor 4.6l engine; 24# injectors; 190 lph intank pump; Marauder MAF; 75mm BBK t/b; Trick Flow Upper intake; SCT ProRacer Flasher; Performance Automatic AODE valvebody; Underdrive pulleys; 3.73 FRPP gears and Trak-lock; Level Ten 3000rpm converter; Ford shorty headers cut and welded to fit; 2.5" cat-back with X, high flow cats; NOS 05-171 4.6L Dry kit
    Aug 2005
    JUPITER
    Quote Originally Posted by Andras
    Why are the MM's so much heavier? They have the aluminum block, lighter hydro formed frame and other aluminum components?
    2003 300A Black MM
    Aug 2005
    TAMPA BAY & SNOW BIRD MAINEIAC
    Larger tires on the ground and bigger egos behind the wheel. And maybe a couple of other minor things. Dennis
    GOD bless my friends, Paula, Cheese(Rex) and Alex and all those still with us.
    Semper Fi
    SUPPORT THE WOUNDED WARRIOR FUND
    2012 HTRDR Lincoln MKT AWD Twin Turbo SHO Eco boost MOTOR
    04 DTR "FruitPunch"5/17/04 Living with the "LEMONADE" in Ed's garage...
    TRILOGY EATON #110 11-25-05
    TRILOGY Twin Screw #003 Thank you MCM & JERRY BARNES
    Install by THE STOOGES
    ASS TUNE by LIDIO
    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
    --Winston Churchill
    Dec 2004
    plymouth, mn
    Quote Originally Posted by juno
    wheels, tires, brakes; maybe, power seats, subwoofer, DOHC vs SOHC, intake manifold (is the SOHC plastic?)
    jeremy
  1. Replies: 38
    Last Post: 11-21-2006, 08:36 PM
  2. Potential new Marauder owner? (many questions...)
    Last Post: 02-02-2005, 12:32 PM
  3. I Saw A Marauder This Morning!
    By 423REED in forum Windy City Marauders
    Last Post: 10-04-2004, 04:13 AM
  4. New Marauder Owner
    By Z-Rauder in forum Shop Talk
    Last Post: 09-08-2004, 05:57 PM
