Results 1 to 6 of 6
Thread: Guage lights and Autometer lights not as bright as I think they should be
    Jun 2012
    Bradenton, FL
    My Guages and Autometer Guages are not seeming as bright as they should be with the brightness at full. Is there a known issue with these? Any idea on how to correct it?
    2003 MM - #1264 of 7838 Black
    JLT performance intake
    2.5" catless custom X-pipe exhaust with Flowmaster 40 series and 3" MEGS res. delete tips
    4:10 Gears
    265/50r18 Nitto NT555 rear tires.
    Quote Originally Posted by ssikpiyelnats View Post
    The only known issue with the illumination is a slight flicker at idle, which seems to be random. Have you looked an another Marauder to see if your lights are actually dimmer than normal?
    Feb 2011
    Hawaii
    I never did convert yet but I plan on using LEDs for the instrument gauges and from what has been said/told these are much brighter while generating less heat.
    You might want to think about converting.
    BTW: different loads can be causing the instrument lights to dim and not be bright or a bad connection/ground....
    ^^^^^ What he said. ^^^^^ Go with LEDs.
    Smoke Cloud
    Just did a full LED interior upgrade!
    FTW!!!
    The KING of BLING!
    BOOST GETS YOU IMPERSONATED!
    I can supply LEDs if you need them.
  1. My Volt oem autometer gauge lights Went out.
    By guccijayda in forum Shop Talk
    Last Post: 10-15-2014, 06:58 PM
  2. Wanted To Buy guage pod / dash trim / reverse lights
    By Daviddc114 in forum Marauder Parts/Misc. Wanted
    Last Post: 08-24-2011, 10:48 PM
  3. Wanted To Buy reverse lights / guage pod
    By Daviddc114 in forum Marauder Wanted
    Last Post: 08-14-2011, 08:04 PM
  4. Wanted To Buy Reverse lights / guage pod / dash trim
    Last Post: 08-11-2011, 10:20 AM
  5. autometer lights
    By visionmercury in forum Shop Talk
    Last Post: 02-02-2010, 08:29 AM
