Results 1 to 15 of 25
Thread: Any 5.4 experts out there
    Aug 2003
    Battle Creek, Michigan
    My wife's 2000 5.4 is leaking at the intake. Quick research indicates not a gasket, but a new intake?
    Leaking between the aluminum and plastic?
    What's the most likely issue?
    First retailed 2003 Marauder
    Bought 6 June 2002
    #168
    Correct. Very very common. A little piece of plastic breaks off underneath and allows the gasket to slip. Dorman makes a better replacement and comes with the gaskets.
    May 2018
    Winfield, MO USA
    I'll second that.
    My 2001 MGM still has the full plastic intake manifold. Behind where the alternator bracket mounts to the intake and right at the temperature sensor I have two cracks. I purchased the new intake but did not have time to put it on so I just used epoxy as a temporary fix. That Dorman intake is really the way to go. They have certainly improved the factory design.
    Aug 2003
    Thanks guys. $200 at Auto Zone and a Saturday should take care of it.
    Bought 6 June 2002
    #168
    Hiram, Georgia
    This ^^^
    Quote Originally Posted by kirk View Post
    And that ^^^
    Oct 2010
    PA
    Quote Originally Posted by 01MercGMLS View Post
    I'll second that.
    My 05 GM had the same issues....... I put a P-51 intake on it. LOL
    SEMPER FI From York, Pa
    Aug 2003
    Bought a Dorman intake (Autozone Duralast branded) today. Might be a couple of weeks before I can put it on.
    The fact that they had one on the shelf indicates it happens frequently.
    Bought 6 June 2002
    #168
    May 2018
    Winfield, MO USA
    This---^
    That was the same thing I thought when I started doing research on mine. It's utterly shocking when you go to a salvage yard and look at the panther cars. That's where I got my replacement intake and it wasn't hard to find. Actually an original plastic intake would be the hard one to find. All but 2 of the cars there had the Dorman intake and they had TONS of panthers.
    There was a class action law suit against Ford Motor Company about this issue. Not sure what models were included but the last day to file a claim was sometime in 2006. So much for that.
    Worse yet is they stock the $500.00 fuel injection spider assembly for GM’s 4.3 thru 5.7’s too!
    Wisconsin
    That's too funny, I've never seen one fail!
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Seriously? I believe I’ve done four now.
    The poppets are known for sticking wide open causing long delayed starts and cylinder flooding ultimately causing a no start.
    Wisconsin
    Well I learned something today, good to know.
    With all the 4.3 V6 S10 p/u's, Blazers & Astrovans I've worked on (many with high miles) over all these years, never ran in to it.
    Thanks Bob.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Feb 2017
    New Orleans, LA
    Ive changed my fair share of injector spiders on the 5.7s on suburbans and tahoes in my day. The cylinders usually fill up with fuel and require you to remove all the plugs and spin it over to get the fuel out. The first time I did one was on my bosses truck and the engine hydro locked after I had it all buttoned up and went to start it. I remember my sphincter was swollen shut til I heard it running actually run I was hoping and praying it didn't bend a rod and was half expecting it to hang a rod out the block.
    The plastic intakes are pretty common here too. In fact there is quite a few that still make it to us with stock plastic intakes.
    Aug 2003
    A little more help gang
    I got this swapped yesterday/today
    All coils and injectors went in where they came out except that I replaced #5 injector
    Everything back together, started up and out for a test drive and warm up
    Runs great, no visible leaks, except it idles like crap at about 500 RPM
    Throws 3 codes, p1000, p1131, p1151 - lean on 1 & 2
    I cleaned the head surfaces, don't see any obvious issues, all vacuum lines accounted for, torqued per instructions
    2000 Expedition 2WD 174k
    Showing it's age, but is solid and ran well Friday
    Any thoughs?
    Bought 6 June 2002
    #168
    I would just go back thru all electrical connections and make sure they are fully clicked on and all vacuum lines, intake boot, and EGR pipe is fully seated. I’m sure it something simple.
    Twice now I’ve had Fords act up because of electrical connections not fully seated. Once an injector, the other was A/C. They seem to be quite picky about being clicked fully.
  1. calling all 1320 experts
    By Chayton in forum Drag Racing Round-up
    Last Post: 10-24-2018, 05:46 PM
  2. Any X-100 experts out there?
    By kirk in forum The Classic Lounge
    Last Post: 05-28-2016, 10:13 PM
  3. Android Experts - Get In Here!
    By MM2004 in forum The Lounge
    Last Post: 09-24-2012, 09:27 AM
  4. Mm Experts Apply
    By Ralph Sr. in forum Test Forum
    Last Post: 05-15-2007, 04:39 PM
  5. Exhaust experts: WTF is this???
    By Alan in forum Exhaust
    Last Post: 05-17-2006, 11:19 AM
