Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: Low brake pedal
    Low brake pedal
    My car only has 30k on it, the car stops well and did not pull but the pedal seemed a bit low, like the brakes dont catch untill half way down with the pedal. I figured i would give the brakes a freshening and put on all new pads and get the rotors surfaced. I also flushed all the old fluid out, I feel pretty good about not getting any air in the system. Got it all completed and it feels exactly the same. All the pads i removed looked real good and the rotors cleaned up nicely. So whats next? master cyl? anything im missing? Im thinking of re-bleeding it all again to be sure about that.. I see in an old post someone mentioned braking on a gravel road to cycle the abs pump in case there was air in it?
    Any thoughts?
    Matt
    03' Blue/Charcoal, Gone
    04' DTR, Gone
    Apr 2005
    Queens NY
    Im having the same issue. I changed the fluid, all new brakes, bled them numerous times, a new master and the pedal still sucks. I have some SS lines I plan to install soon. I hear that helps the pedal feel.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Do you have SS brake lines? Those can help increase the feel of the pedal.
    Mine are the same way you are describing yours. I have SS brake lines, new OEM pads/rotors/calipers up front and new pads in the rear.
    How does one test the master cylinder to see if it's working 100% proper?
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Hiram, Georgia
    Replace the master cylinder.
    Rebleed brakes.
    ***The master cylinders on our cars suck***
    Go with OEM or is there a good aftermarket company to get one from?
    300B
    Exhaust by Greg
    Hiram, Georgia
    I believe that the one I used was made by Wagner. I bought it from O'Reilly's.
    Make sure that you get the right one (traction control cars need a different one than a non-traction control car).
    Thanks for the info Marty!
    300B
    Exhaust by Greg
    Apr 2010
    Denver, CO
    Quote Originally Posted by martyo View Post
    Good to know, thanks.
    2003 MARAUDER
    Lidio Tune
    JLT Intake
    Aero Turbine 2525 mufflers
    No 2nd cats
    Resonator Delete Tips
    NGK TR6 Plugs
    180* T-stat
    Jun 2005
    East Lansing, MI
    I have SS lines etc. and my pedal is the same way too. I even convinced myself that I had air in the line after the line lock install. . . then I remembered
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    Hiram, Georgia
    One other thing, I think these are "core" parts, so save the one you pull out because you will need to return it for the core charge (like 20 bucks).
    Are people just replacing the master cylinder and/or the brake booster also?
    300B
    Exhaust by Greg
    Hiram, Georgia
    I did just the master.
    Another thing is to thoroughly flush the fluid because when the master cylinder goes bad teh fluid gets contamintaed.
    Thanks guys. The one thing i do notice is the pedal is low on the first hit but if you do a second hit right away on the pedal its up where you would want it to be. I will look into getting a new master cyl. and doing another bleed of the system. So is there anything about cycling that ABS pump?
    Matt
    04' DTR, Gone
    Apr 2005
    Queens NY
    Quote Originally Posted by Matt In Detroit View Post
    Check for vacuum leaks. I noticed I would have strong brakes after a second pump due to my intake manifold being a little loose.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Jun 2010
    Western Kentucky
    I have an 04 MM and does the same. Also have trail blazer that when at stop light I can push the pedal to the floor and pump again and it is tight. Brake man said that is normal for ABS.
    USAF Retired
    2004 DTR Light Flint 38,100 miles
    Moonroof, Heated Seats, CD Changer,Trunk Organizer
    Born 3/29/2004, Adopted 6/15/2010
    #2209 of 3214 & 738 of 980 DTR
    2012 Lincoln Navigator
  1. Crunchy Brake Pedal?
    By Vortech347 in forum Steering, Suspension & Brakes
    Last Post: 08-20-2010, 11:16 AM
  2. Noisy brake pedal?
    By khc3 in forum Steering, Suspension & Brakes
    Last Post: 07-25-2007, 03:33 PM
  3. Squeaking brake pedal
    By kdjlaw in forum Shop Talk
    Last Post: 06-21-2006, 05:28 PM
  4. A Knocking in my brake pedal
    By MarauderMark in forum Shop Talk
    Last Post: 10-09-2004, 06:55 PM
  5. Brake pedal travel
    By jcb100 in forum Shop Talk
    Last Post: 04-02-2004, 09:49 PM
