Results 1 to 4 of 4
Thread: 2003 trannmission code
    Jun 2010
    Boston
    I received a code P1728 'transmission slip malfunction'. code this be a sensor issue? Also is the transmission in a 2003 Marauder the same as in a Crown Vic or Marquis?
    Feb 2017
    New Orleans, LA
    ive never seen it but trans slip codes dont usually end well
    yes the vic and marquis trans is the same. The 03 & 04 marauder trans are easily interchangeable as well just need to update the oss teeth count and apply more 3-4 blip pressure for the 04 / 4r75w trans when used in an 03. That's the only two very minor tune adjustments.
    wrong.
    No grand marquis or civilian crown vic trans is the same.
    Only 01 02 03 P71 and I believe town car.
    Car-part.com lists plenty of long tailshaft marauder style trans
    Feb 2017
    New Orleans, LA
    bryan is correct the tail shaft housing is shorter on the other trans
    but any aode/4r70w/4r75w trans out of any town car, marauder, mark viii, mach-1, crown vic, marquis, thunderbird, mustang, f-150 and e-250 w/ modular trans can very easily be swapped in but would require a slightly longer drive shaft if the trans has the short tail shaft housing.
    Other than updating the oss teeth count and applying more 3-4 blip pressure for the 04 / 4r75w trans when used in an 03 you would have to update the trans ratio if using an aode from a 91-95.
    as far as a direct swap in it would take a long tail shaft housing trans to keep the stock drive shaft length.
  1. Air bag code 2-2
    By Big House in forum Interior Electrical/Electronics
    Last Post: 01-19-2018, 01:55 PM
  2. Code name?
    By Mr. Man in forum Community Discussion
    Last Post: 08-23-2017, 07:24 AM
  3. can a P71 have a different code in the vin?
    By johnnyrauder in forum The Lounge
    Last Post: 10-20-2016, 06:05 AM
  4. DTC code
    By bigmerc'03 in forum Transmissions
    Last Post: 05-13-2009, 08:37 PM
  5. Trannmission Squeak
    By dalucifer in forum Shop Talk
    Last Post: 09-29-2007, 02:53 PM
