Results 1 to 15 of 24
Thread: Bench testing suspension compressor
    Aug 2013
    Woodridge, IL.
    Hey guys, I wanna test my compressor before I spend the money on a new one, can anyone give me a step-by-step how to do it?
    Sent from my 2PS64 using Tapatalk
    Give it positive and negative.
    Aug 2013
    Woodridge, IL.
    With the car running, can I do that straight from jump wires connected to the battery, to the black and red pinhole connections on the compressor?
    Lehigh Valley, PA
    Quote Originally Posted by tylerdurden2816 View Post
    Do you want to just test if the compressor works or are you trying to jump it to fill the bags?
    If you're trying to fill the bags, you need to make sure the solenoids open up which they'll only remain open for a certain window of time.
    Normally when I was ever testing a car with a bad compressor, I'd just slap a known good compressor on since its so easy to change. You don't need the car running, just key on, open/close a door so it trips the solenoids open (as long as it isn't at ride height, you'll hear a click when they open), then you could jump the compressor to put air in the bags.
    I have never had to jump a compressor before, if yours is dead and looks rusty 95% chance it's the problem. Happens to everyone at some point.
    2063/3214
    5377/7838
    Aug 2013
    Woodridge, IL.
    I'm trying to test it before replacing it. So, I don't have another one yet, I want to test this one to see if it will even turn on. I'm pretty sure it's bad, but at $120 minimum, I'd really like to be positive first.
    Lehigh Valley, PA
    At that point I'd just disconnect the airline and jump it.
    I don't remember the pinout for our cars, these may be the same
    https://www.crownvic.net/drock96marquis/RAS.htm
    2063/3214
    5377/7838
    Aug 2013
    Woodridge, IL.
    The connector has four points, and I saw a red and black, so I assume I can just go direct from the battery to those with a couple jump wires.
    Lehigh Valley, PA
    I mean, you can't make it any worse than non working
    2063/3214
    5377/7838
    Aug 2013
    Woodridge, IL.
    my thoughts too lol! I was just looking for somebody who may have done it before to confirm that was correct to avoid a false negative.
    BK - Ground
    PK - Solenoid vent
    BK - Ground
    GY/RD - Compressor relay, switched power
    Aug 2013
    Woodridge, IL.
    BK - Ground
    PK - Solenoid vent
    BK - Ground
    My compressor doesn't have the same colors you're describing. Held looking into the holes like in the first picture, the individual pinholes look like a compass ("North" being the hole closest to the connector clip), and their wire colors are as follows:
    North-Red
    East-Blue
    South-Green
    West-Black
    Keeping this configuration in mind, can I run a jump wire from my car battery's (-) to the black(West) hole and another jump wire from car battery's (+) to the red(North) hole, with the car running, to properly test if this compressor will run anymore?
    Aug 2013
    Woodridge, IL.
    North-Red
    East-Blue
    South-Green
    West-Black
    After seeing how crusty the motor is.. it's prolly toast..bench test it for piece of mind.
    Aug 2013
    Woodridge, IL.
    My thoughts exactly. Is the way I described a proper way to test it?
    North-Red
    East-Blue
    South-Green
    West-Black
    What about the vehicle side colors? Jump the one on the flat side of the connector with the one directly across from it.
  1. bench testing an EATC
    By robertmoreno14 in forum Interior Electrical/Electronics
    Last Post: 01-31-2016, 03:29 PM
  2. Air suspension compressor
    By burt ragio in forum Steering, Suspension & Brakes
    Last Post: 08-01-2015, 10:17 AM
  3. Testing the air compressor
    By Big House in forum Steering, Suspension & Brakes
    Last Post: 08-19-2012, 06:02 PM
  4. Air suspension compressor
    By vmaxmarauder in forum Other Parts/Misc. Wanted
    Last Post: 11-18-2008, 06:36 PM
  5. Air suspension compressor
    By ctrlraven in forum Marauder-specific Parts for Sale
    Last Post: 03-10-2008, 04:58 PM
