Well, totaled the marauder a few days ago...
https://www.svtperformance.com/index...reads/1175494/
'03 300A Marauder, 107K miles, flowmaster 40 series mufflers, 2nd cats deleted, HID 6000K foglights, SilverStar Ultra's headlights, goodyear gatorback belt, K&N FIPK, K&N drycharger, SS inserts, spoiler, MSD COP's, Nitto Motivo's.
Sorry to see that. Someone was selling a complete interior here recently, might still be available. Any water in the engine? You might end up with a salvage title but if your mechanical I say try and fix it. If you don't want to someone here might.
My sympathies.
I once totaled a '94 T-bird in 4" of water. The under car wake blew water into the intake tract. Bent the rods.
"No one is useless if they can still be used as a bad example." ~ SSgt. Miller.
"Loud pipes lose rights."
Gonna be too much work for me and my work schedule is insane
Definately not the best decision driving through that much water
I would consider this an easy fix.
Heysus Christe? Did you leave your seeing-eye dog at home?...ended up accidentally driving through a large flood area since I wasnt able to see it.
Cool, again, raining cats and dogs... flash flood...
Know what, better yet.. HALF RIGHT, FACE!!
Some when in that situation can only think that they have to get through it.
Had several family members do the exact same thing.
Hope it all works out for you.
I've been in storms like that.....
EVERY inch of road has at least 2" of water covering it.
Can't tell 2 inches from 2 feet.
Without a 'leader car' out in front of you....you have no idea what's coming.
Sorry to hear about your Marauder.
Glad you’re ok!
