Results 1 to 11 of 11
Thread: Spark Plugs?
    Houston, Republic of Texas
    Spark Plugs?
    At 54k, I don't think I really need new plugs, but what the heck, I feel like doing something nice for my MM. I'll probably put in a new set this weekend. I have the OEM thermostat, so I need plugs that work at the factory temperature range.
    What plugs are some of you using with the factory stat?
    2003 MM 300A
    Born June 18, 2002
    Adopted Christmas Eve, 2002
    First Factory Rebuilt Ford P.O.S. Engine at 81,000 miles
    Second Factory Rebuilt Ford P.O.S. Engine at 101,000 miles
    Ford Racing 4.10's
    Reinhart/XCal2 Custom Tune
    Reinhart Underdrive Pulleys
    K&N Conical Air Filter
    Reinhart Exhaust with 18" Magnaflows
    Silencer Removed
    Bosch Micro Edge Excel Wiper Blades
    Bob White Red Bumper Inserts
    Lone Star Beer in cup holder
    Fellowship of Christian Cowboys
    license plate bracket
    God and the soldier we adore, In times of danger, not before.
    The danger gone, the trouble righted, God's forgotten, the soldier slighted.
    Cynicism is the smoke rising from the ashes of burned out dreams.
    WOW! 63 views and no responses! I guess most people are like me, unless they have changed their stat, they haven't changed their plugs yet.
    2003 MM 300A
    Born June 18, 2002
    Ford Racing 4.10's
    Silencer Removed
    Nov 2003
    Horntown, VA
    Quote Originally Posted by Ross
    Ross - check my signature.
    No, I have not changed my program & have been running the stat/plugs for over 10k miles. Nice SOP. Spins tires from dead punch & @ 1-2 shift.
    Plate - "EVILMERC"
    Thanks, buddy!
    2003 MM 300A
    Born June 18, 2002
    Ford Racing 4.10's
    Silencer Removed
    Ross, if your chip programmer didn't require a cooler 'stat and plugs, then why not just keep using the factory-recommended ones? The part number's in the owner's manual...
    Well, since I am adding some new ones, I thought I'd see what else was available that others might be using, just for the heck of it. Especially since plugs are cheap compared to a lot of other things that we do to these cars!
    2003 MM 300A
    Born June 18, 2002
    Ford Racing 4.10's
    Silencer Removed
    I'm not sure what plugs you use... but on my 4.6L SOHC V8, I'm using AGSF-12FM1 (Motorcraft) plugs that look just like Denso Iridium spark plugs, but at $4/ea.
    Washington DC
    I am using NGK Iridium spark plugs (TR 55IX 7164) on stock stat.
    Merc's Garage
    Orlando, FL
    Everytime ya do somethin nice everything kinda f k's up, leave it alone till it needs em.
    Warson Woods, Missouri
    Plugs
    I'v got several sets of OEM low mile plugs you can have. The S/C car takes an oddball, gapped at .032. That's odd too, but I understand it helps with quicker flame travel, which must be good.
    John
    Jun 2002
    Pleasant Hill Ca. - across the bay from San Francisco.
    Post
    Ross,
    I have the same MM with a older Diablo chip also. Your plugs do need changing. Look up spark plugs on search - we have many comments and lots of discussion.
    After lots of research and talking to factory tech's. I came to the conclusion
    that a one step colder plug would improve performance by better combustion and less spark knock. The Denso Iridium 4mm extreme HP plugs NO. IT20.
    These make a larger spark ball than any other plug. Set the gap at 50 with care. They use a stronger Iridium - different composition - than any other.
    It takes 30 min. to change the stat. (to 180deg.) and plugs.
    Use flat clamps to pinch off the hoses to the stat. then just changeout.
    Be sure to put new one back in same way otherwise it will leak. You will loose 1 cup of fluid only. Repace and burp thru tap on cross pipe in front.
    Your MM will be happier with less knock, more advance and power.
    You will notice the difference.
    Call Dennis Reinhart as his firm has the plugs and stat. and he has great
    advice and knowledge. Consider a 410 rear also.
    WarrenB
  1. Extended Spark Plugs for FE's ??
    By Thomas C Potter in forum The Classic Lounge
    Last Post: 02-14-2005, 07:23 PM
  2. Replies: 4
    Last Post: 10-11-2004, 06:54 PM
  3. Bosch spark plugs?
    By rayjay in forum Community Discussion
    Last Post: 08-15-2004, 09:17 AM
  4. changing spark plugs
    Last Post: 01-06-2003, 12:12 PM
