Results 1 to 15 of 17
Thread: engine misfires
    Jan 2009
    birmingham
    Angry engine misfires
    my engine keeps mis firing but the check engine light is not on and i checked the cylinder coils and that was not the problem either. i took it to the shop and they couldnt find what was causing it. has anybody on here had this problem also? if so what causes it?
    Apr 2005
    Queens NY
    Quote Originally Posted by djyelloboy View Post
    Hopefully you don't have the dreaded burnt valve from lack of cooling in the head. Is it popping out the exhaust on the driver side?
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Did you check your spark plugs? One may have backed out.
    We really need more to go on here, MPH, idle, how many miles, what was done recently???
    May 2007
    Massapequa Park
    Do a compression test, then go from there. I like you started with evrything but the compression test $200 dollars in parts later I needed the heads rebuilt.
    Jan 2009
    birmingham
    it does it mostly when goin up a hill or pulling a load. its most common at around from anywhere between 30 and 60 mph. nothing was done recently to it and it only has 56,000 miles. i didnt check the spark plugs and i dont know about the burnt valve.
    Apr 2008
    Conneticut U.S.A.
    First things first. When the engine is stone cold after sitting over night check each of the spark plugs make sure they are in proper if all is okay there pull them out one @ a time and take a look to see if any of them look differnt from the others it might help with indicating which cyl is miss firing. Check the gap and so forth.
    If you have an ohms meter preferably digital to get a more acurate reading check the coils put the pos lead on the left hand prong of the wire conector and run the neg lead to the bottom of the spring. Mark down the results of each coil check and see if you have a problem there.
    If you can rent a set up to do a compression check while your @ it just to make sure there is no problem internaly and log the results.
    If you find nothing on all 3 counts then you need to do a load test @ a shop where each cylender can be checked to see which of the coils are cutting out on you under pressure.
    Doing the first bit of the process on your own if your capable will save you some bucks instead of paying a shop to do it all.
    Once you have more info to present someone might be able to help you further.
    Assembled 12/17/2003
    #1183 of a build of 3214
    and is #379 of 1237
    Link to Mod's and car:
    Aug 2006
    East Texas
    If you can rent a set up to do a compression check while your @ it just to make sure there is no problem internaly and log the results.[/QUOTE]
    AUTOZONE may let you use one for free if you stay on the property and don't leave. That is where I found that cylinders 7 and 8 had low (125 and 65lbs) compression. They are fixed now FWIW
    Rick
    2003 MM 300a
    Trilogy #109
    CAI
    Cobra 18" Wheels
    Tint Job
    Chromed Grill with Badge Delete
    Everything else Stock
    Oct 2004
    Dude don't get so discouraged just find a good shop or Mercury dealer not some wrench head with greasy pants that calls himself a mechanic. If you can't do the work of previous posts mentioned. I'am sure it is a simple fix.
    I'm a wrench head with greasy pants? LOL To get the most accurate readings doing a compression test, it should be done with the throttle body wide open. Autozone rents these for free and yes you can take it home. I crank from 5-7 seconds per cylinder till the guage goes up and levels off, record each cylinder onto paper. I remove all plugs and throw the COPS all to the side and remove the fuel pump fuse. This way you can check all eight in a matter of minutes. Whole job = 20 minutes start to finish. And I do mine on a slightly warm engine............flame suit on.
    Jan 2008
    +34 Dg 32' 39" X-82 Dg 40' 24"
    sounds like coils, or the connector springs.
    "A street walking cheetah, with a heart full of napalm."
    "If You can keep Your Head About You, While Others are Losing Theirs and Blaming It on You..."
    "Sometimes it is wiser to remain silent, and seem a fool, than to speak, and remove all doubt."
    "We've been looking for the enemy for some time now. We've finally found him. We're surrounded. That simplifies things."[5]
    Oct 2004
    Didn't mean for you to take it the wrong way it's an expression. As you can see I did say to try the above post mentioned that are suggested by knowledgable people. I should have clarified it further "knowledgable wrench heads" No disrespect ment.
    I was pulling your leg friend, I knew what you meant. I have VERY dry humour sometimes.
    Jan 2009
    birmingham
    ill probably just end up taking it to the shop cuz i really dont havew the know how to or time being in college and playing football! but thanks for all the input i really need to learn more about my car!
    Oct 2003
    Beaufort, SC
    Quote Originally Posted by trash View Post
    ^^ BINGO!!!
  1. Help. Can't get my engine out!
    By Motorhead350 in forum The Lounge
    Last Post: 08-02-2008, 04:09 PM
  2. KB MM engine
    By PhastPhil in forum Other Parts for Sale
    Last Post: 10-22-2007, 04:26 PM
  3. Difference: MM Engine & Mach1 Engine
    By Rider90 in forum Shop Talk
    Last Post: 07-07-2005, 04:51 AM
  4. While the engine is out. . .
    By jjaguda in forum Shop Talk
    Last Post: 02-05-2005, 02:07 AM
  5. You're not going to believe this engine...
    By ghost in forum The Lounge
    Last Post: 07-08-2003, 08:18 AM
