After 6 weeks of rest and recovery i returned to the track. As a spectator it was good to smell the smoke and hear the peeling tires. Here are some pictures from the Northern Virginia Mustang Club private track rental.
Merc's Garage
The SB looks good Merc.
Merc's Garage
its weird seeing pics of your SB. cant wait to see it in person.
when will the swap over start?
Merc's Garage
thats a bad bird
Glad to see your SB, sun roofs are fun.
Are you scratching an itch or just having fun or both?
Welcome to the SB club Mark!!!
Needs a spoiler and Mach 1 chin spoiler.
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
Mark you will find the SB easier to keep clean. And probably faster . In the fall I too will be back at the track myself working on going at least a 4 tenths lower et. Best of luck with your drivetrain swap.
former owner - Extreme Procharger Marauder
2004 Silver Birch - Built 01-08-04 - Pur. 07-03-04
"Proud Member of Sunshine State Marauder's"
Extreme Procharger Bullitt Completed - still on the hunt for another 04 Marauder to build
Mark,
Congrats on your new SB Marauder!
Looks sweet.
Glad to see that you aren't 'gun shy' of the track and might get back in the saddle soon.
BTW: Is that "The Shermanator" lifting the front wheels again?
Marc,
I am glad to see you are near the track...I hadn't been back since shelling out nearly $1200 getting my rear end fixed...TWICE!!!! Will be back though. Get at me.
House
Welcome to the DARKSIDE...
2003 Black Mercury Marauder
Black and Chrome RPM 505 wheels staggered 18x8 and 18x9, Custom tune by ELD Performance, JLT cold air intake, FRPP 4:10 gears, PI 3000 Stall Torque converter, PHP intake spacer, Stainless Works Complete Exhaust, Eibach Pro Springs, Steeda underdrive pulleys, Custom Painted Black factory spoiler, 15% Tint front and rear , Kenwood Excelon 6x8 Front and 6x9 rear Speakers, Pioneer 600w 4 channel amp, Zack and Mack Control arms, Addco Front and Rear Sway bars
Best run: 13.75 @ 99.6 sec on 4 May 07
nice SB Mark, that is the setup i wanted before i bought this car.
you wont regret you color choice.
Glad to see you up and doing fine..Nice SB..
Nice pics, Merc. Be a nice guy, Bad Merc could use your let rear door. Thanks for the thoughts during that first run yesterday.
Sherman
2003 Marauder 4.6
3.4 Whipple Crusher
Custom CAI down in bumper cover
Local built Trans with extra direct clutches (ATS Newington, VA) Circle D 3000 stall Triple plate converter
Custom Sumped stock fuel tank Aeromotive Pro Series Pump with Controller Return Style pumping E85 through ID1300 Injectors
4.10's Detroit Locker 28x10x16 Hoosier Drags on widened 16" Mustang rims, CHE Control Arms
Custom Headers with 2" Primaries and 3.5" Collectors
