Results 1 to 15 of 15
Thread: air suspension compressor
    Oct 2009
    Middle East - SA
    Good day everyone
    Today when i was back from work I fell something wrong
    I get out from the car I found the car below
    After five minutes the air suspension light come on just like that without any signal
    I check the system for air suspension by OBD-II checker
    Its say the air suspension compressor have a problem
    I check the raley and I make a direct wires from the battery to the composer it not working
    So i check the agency and dealer for spare part the computer say the marauder have a special compressor
    And it not available on here
    the big problem is I need the car and top the that its too expensive around 450 $ just for GM and CV
    So what's gonna be
    Any thought. ......!!!
    Dec 2008
    South Carolina
    http://www.arnottindustries.com/part...id9_gid45.html $200 AND BETTER THEN OEM AND TAKES 20MIN TO INSTALL
    Adopted 3/31/11. Sold
    03 300a black #1199
    TERMINATOR SWAP
    430rwhp. Done by mo's
    ^^^what slickster said^^^
    I have one of the Arnott replacement compressors in Phoebe. Quieter than the original was when new. Works perfectly.
    Quote Originally Posted by slickster View Post
    What they said^^^^^^^^^^
    Jan 2008
    +34 Dg 32' 39" X-82 Dg 40' 24"
    Try this till you get a new compressor;
    OK, heres what you do to get the car back up to ride height (if its the compressor that died, not the bags that blew.)
    This works a little easier w/ 2 people, and an air compressor with a rubber tipped air nozzle (worked well for me, the tube type may as well if thats all you have) a small 5 gallon (@ 80ish psi) tank should have enough air in it. It doesnt take much air to get the bags back up
    Pop the trunk, you will need access to the air ride switch. Remove the air box (if you have it, or other intake assembly) to reveal the suspension compressor beneath. locate the air line coming out of the small tank attatched tot he pump. remove the air line. Push the colored ring in and pull the tube out to remove it.
    with the air ride switch in the on position,and the air compressor all ready to go, have a buddy hop in the car and turn the key to 'On' but dont start it. in a couple seconds you will hear the compressor kick on/grind/howl (whatever noise it makes if any) and/or you will hear the solenoids 'click' from the rear bags. once you hear either of those, start pumping air from the compressor into the air line you removed. that will start to inflate the rear bags. keep filling until the suspension pump stops, or the rear solenoids click shut, or until you get whatever rear height you want.
    once you get to the desired height, go to the trunk and flip the air ride switch off so that the computer doesnt make the solenoids open again and you lose all your air. FYI having the air bag switch off will also make the 'air ride' light come on in the dash.
    thats how you can manually add air to the bags and still drive around with a broken compressor. I did that for a week when mine went out..
    also, my pump died because of the windshield washer reservior. You cant fill it more than 3/4 full otherwise it will slosh out of the little vent hole in the top of the cap and leak down onto the suspension pump and corrode it until it dies.
    "A street walking cheetah, with a heart full of napalm."
    "If You can keep Your Head About You, While Others are Losing Theirs and Blaming It on You..."
    "Sometimes it is wiser to remain silent, and seem a fool, than to speak, and remove all doubt."
    "We've been looking for the enemy for some time now. We've finally found him. We're surrounded. That simplifies things."[5]
    Oct 2009
    Middle East - SA
    Thanks man there is two air line
    one below the air intake coming or going to the bags and one coming out from comprusser to a small box already wrote marauder on it
    and how I remove it cause i afried I broke it
    The white box with "Marauder" on it is the vent for bleeding off air when the car is unloaded. It's not critical. The other line is the one to the air bags. Push in on the orange "ring" that the line plugs into on the dryer and the line should release.
    Oct 2009
    Middle East - SA
    Today i change the compurser
    but the hose line to the bags doesnt plig completely when the compu. Work i hear leaking when i try plug good its work
    is any one tell me how I make it good
    cause i need the car
    Apr 2005
    Queens NY
    Quote Originally Posted by yryr999 View Post
    You have to put some pressure to push the lines in. also make sure you hooked then the right way. If the compressor is on and its pumping out the vent, switch them. I havent had a compressor issue yet but so I'm not 100% what the lines look like. I know on the Mark8, you have to push them in hard to prevent a leak..
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Paul, you can't mix up the lines, they won't reach.
    yryr999, I don't quite understand...where exactly is it leaking from? If it's the main connection, you may have to do as Paul suggested ^^^ and push down on the orange ring while inserting the hose to get it to seat all the way in.
    Aug 2013
    Woodridge, IL.
    Arnott doesn't make the compressor anymore anyone have a suggestion where is best to get one now?
    Sent from my 2PS64 using Tapatalk
    They still make it, got one on Amazon weeks ago..
    Aug 2013
    Woodridge, IL.
    I found it on Amazon, $215, but it's not on their website for some reason. However, Suncore has one for $120, any reason not to go with them instead?
    Suncore has been used here before with no reported issues I know of
    Euless, tx
    I think I might need one aswell everytime I cut it on it blows a 30amp maxifuse under the hood if I leave it off everything is fine.
  1. Wanted To Buy Air suspension compressor
    By freakstatus in forum Marauder Parts/Misc. Wanted
    Last Post: 04-15-2011, 07:38 AM
  2. Wanted To Buy suspension compressor
    By shodude in forum Other Parts/Misc. Wanted
    Last Post: 03-21-2010, 01:52 PM
  3. For Sale WTB - Suspension air compressor
    By MinnesotaMuscle in forum Marauder-specific Parts for Sale
    Last Post: 11-17-2009, 09:00 PM
  4. Air suspension compressor
    By vmaxmarauder in forum Other Parts/Misc. Wanted
    Last Post: 11-18-2008, 06:36 PM
  5. Suspension compressor
    By Wags in forum Shop Talk
    Last Post: 11-08-2006, 09:17 AM
