Results 1 to 15 of 19
Thread: Drivers window suddenly in op
    Nov 2012
    Sacramento
    Read previous thread on topic. Drivers side front suddenly stopped working. No noise, no issue. Switch feels "faint or light.
    Super clean low mile interior/exterior.
    Will check for dome light/ power to switch, and beat on outside door while activating switch.
    Jun 2007
    Whitehall, PA
    Take it apart and clean the contacts
    2003 DBP/LF - # 36 (Sold)
    2003 DBP/LF - # 205 (Sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox
    Nov 2012
    Sacramento
    Cool what is the secret not to break the tabs of the switch cover? What tu use to clean the contacts? I have maf cleaner (just an idea).
    Oct 2008
    Massachusetts
    My window recently became inop, one good smack on the door panel and all is well.
    Nov 2012
    Sacramento
    GOOD SMACK fixed the issue. Sorry for the two threads, AND THANK YOU to all who replied to help. The door open, key on {car off} advice to try switch and watch for Dome light to dim slightly indicating power to the switch/ switch power was classically brilliant. THANK YOU.
    Smiled my ears off that it worked perfectly again immediately after.
    Now that you got it up, can you keep it up?
    May 2018
    Winfield, MO USA
    Dealing with a similar issue. Window went down but won't come up. When I hit the down button the light dims but when I hit the up button nothing happens. I have the door panel off and the switch panel in my hand. I have taken the switch apart to expose the contacts but they look fine.
    Suggestions on how to get the window up for now so I can work on this later would really be appreciated.
    Jun 2017
    Oxford, PA
    Ugh. Take the door panel off , reconnect the switch then tap near the window motor with a hammer lightly while you hit the switch. I assume this Is the Drivers door window...if it's another window make sure child lock switch is not activated...test the switch contacts while hitting the switch using an ohm meter with the switch disconnected.
    Nov 2012
    Sacramento
    OMG... This thread ressurected, and my Red Sled passenger window is now in-op as of this AM.
    Will do all of this again today.
    May 2018
    Winfield, MO USA
    While waiting on replies I tore into the switch assembly. I wasn't getting the slight dome light dimming when trying to raise the drivers window. After messing with the contacts a bit and reassembling the switch the window now goes up again. What a pain in the butt. I hope this isn't a sign of things to come.
    Nov 2006
    Union City, CA
    My driver side rear passenger window wasn't working the other day. Kept pushing the button. Pushed the button on the rear door too. Eventually, it broke lose and the window operates normally now. I think it was just gummed up from dirt etc and not having been rolled down in so long.
    1988 LTD Crown Victoria S
    Nov 2012
    Sacramento
    Fixed the Red Sled inop window today after this thread reappeared. So bizarre, I had completely forgotten about this fix.
    Weird terminator back in time, into the future fix, with this thread reappearing the day before my window stops when working.
    Quote Originally Posted by 01MercGMLS View Post
    What you could have done is removed the wire to the window motor, and flipped the polarity of the 2 wires. So when you hit DOWN the window goes UP.
    For temporary purpose / rain etc
    May 2018
    Winfield, MO USA
    I'll keep that in mind for future issues.
    Thank you.
    Nov 2013
    CT, MA
    kick out the glass. Clean area. Install canvas roll with latch hooks on upper door.
    Solved.
    2004 SILVER BIRCH/BLACK PAINT
    DARK CHARCOAL NUDO LEATHER
    #400 of 997 (SOLD)
    2004 CV LX SPORT
    2004 300A MM BLACK
    1 OWNER CAR, NO OPTIONS
    DAILY DRIVER
    2013 DAYTONA R/T
    SUPER TRACK PACK
    DAYTONA BLUE PEARL
    #1763 off ~2100
    NOW WITH A 392 & 3.73 posi!
  1. Drivers Window
    By sailsmen in forum Shop Talk
    Last Post: 07-09-2018, 10:13 AM
  2. Drivers Window...
    By Ozark Marauder in forum Shop Talk
    Last Post: 12-25-2016, 05:01 AM
  3. Drivers window (only) won't go down
    By Mote in forum Shop Talk
    Last Post: 10-26-2009, 03:26 PM
  4. Drivers Window
    By Brian Humphries in forum Shop Talk
    Last Post: 05-29-2008, 01:40 PM
  5. Drivers Window?
    By TJCOX in forum Shop Talk
    Last Post: 09-06-2007, 05:21 PM
