Results 1 to 15 of 19
Thread: Water, Water Everywhere ........ in NoVA
    The last couple days in Northern Virginia have been rather wet ... to make an understatement. Last night we had another 5.5 inches of rain. Lots of flooding with roads underwater in several areas. Haven't seen this much flooding since June 1972 when "Agnes" went through.
    The Capital Beltway around Washington, DC was closed in both directions in Alexandria, VA due to flooding. Route 1 near Fort Belvoir, VA was also closed. Little streams and creeks that you barely notice were raging rivers throughout the area.
    My little 13 mile commute took a full 2 hours this morning. Some days I hate living in Northern Virginia. Sure hope things get back to normal before the evening commute. The good thing is that the MM is in the shop for a routine check-up, 2 front tires (35K) and the haunted windshield wiper exorcism. I will be glad to get her back tonite.
    Oct 2003
    Md.,NC
    I had over 12" in a bucket this morning and Rt.29 is still closed with water 10 feet deep last night. Tom
    I warned you guysit was coming.
    We just finished the cleanup around here.
    Nearly every house down hill of me has wet carpet out on the treelawn.
    2017 Niro
    Oct 2004
    Rowlett
    Send some our way pleeze, we are on water restrictions and my yard hasnt seen a descent rain since January!
    2005 Dodge 1500 Hemi Quadcab
    2020 Chevrolet Tahoe LS
    Aug 2004
    Maryland
    Did someone say WATER?
    The builder did not grade a drainage ditch properly. It over flowed alittle into our yard. We notified the builder and he sent out a guy with a bobcat to regrade it.
    As you can see, he did a fantastic job
    11.98 @ 115 mph
    Quote Originally Posted by DEFYANT
    Hey Charlie,
    Not to get off topic, but let me know how you ultimately solve this problem. My yard looks exactly the same. I still have't found a solution that works.
    Current:
    2003 Mercedes S600 TT V12.
    525 RWHP
    645 RWTQ
    Stock W/programming.
    Previous owner of:
    2003 Marauder - 300B
    Silver Birch
    Born 06/03
    Heated seats- Light Flint
    6 disc changer
    Silverstars
    Trilogy Kit #22
    Ford SVT Cobra Engine (Longblock)
    17.0 PSI ( 455 RWHP / 488 RWTQ (3500- 4500 RPM) 425 FT/ LBS MIN.
    Alternative Auto tuning
    Accufab Cobra Throttle Body
    SCT 90MM MAF
    Addco front and rear sway bars
    Additional 24000 GVWR tranny cooler
    Baer brakes front and rear
    220 Amp police alternator (130 amp @ idle)
    "Stainless Works" Long tube Headers and complete exhaust. (Max HP gain= 57.9 @ 6,100 RPM)
    Barry, shut the faucet off at your end. The wether man says that this is supposed to continue until well into Wednesday. So far since Saturday, we've had about 11" of rain. Probably 5" more on top of that in the next day or so. I have seen this much water since 1972.
    Quote Originally Posted by G-Man
    From the pictures, it doesn't look like grading or ditching is gonna do the trick. In the first pic, I see part of an 18" culvert that dumps onto Charlie's property. They should have run that culvert completely across and into a natural drainage ditch. I assume that culvert runs under your property line and carries water from the street/gutters.
    As long as that flow is travelling across open ground, it will continue to dig a channel and erode the ground. Your property will become the drainage area.
    You need the contractor to install a concrete V-Ditch .... preferably with periodic cross weir dams to slow down the flow. It can be done; otherwise you are gonna lose alot of ground to the neighbors on the low side of your property.
    Blog Entries
    2
    Bet we had more water. This is our I10 evacuation route. After a $40 million drainage system was installed.
    Oct 2003
    Afhaggisland
    Charlie, there is not much they can do when the ground is wet. You will just have to wait until the rain ends it drys out.
    Saorsa gu Brath
    (Freedon Forever)
    Si vis pacem para bellum
    Μολὼν λαβέ
    (Come and take them)
    Stann saam of sterf allen
    (Stand together or die alone)
    Audentis Fortuna Iuvat
    (Fortune Favors the Brave)
    "THE BLACK BOMBER"
    Aug 2004
    Maryland
    Quote Originally Posted by Haggis
    Gordon, this was right after the rains came.
    There is more. The gully was in more of a V shape before with a little run over. They came out and made the "repair" .
    Here is the builders response:
    Charlie,
    I stopped by the property this morning to inspect the area of your concern. The storm water management system of the entire development has been installed, inspected and approved by the County and the design engineers. The swail that that is along the property line of your lot and lot #15 is working as designed, especially since we were there last week and we regreded and stabilized this area with matting. However on heavy rain storms, and flash floods such as what we have been experiencing that past few days these designed channels can become over loaded, and sometimes overflow. Under normal conditions you will not have this overflow of water onto your rear property. I hope this clarifies your concerns on this issue.
    Should you have any further questions please do not hesitate to call
    11.98 @ 115 mph
    Aug 2004
    Maryland
    You'd think the "Designed channels" were NOT designed correctly, eh?
    11.98 @ 115 mph
    Exactly !!! The ditch on the low side is not sized to handle the maximum flow coming from the 18 inch culvert. That's why it has overflow the edges of the ditch. The cross sectional area of the ditch should at least equal the cross-section of the culvert (254.5 sq. in.). A V-ditch to carry the same flow would have to be 12 inches deep by 42.4 inches wide at the top. It doesn't look that big to me. Obviously, a deeper V would not need to be as wide.
    The second problem is the rate of flow. A 2 to 3 degree grade is typical for culverts and drainage. This is adequate for the "flow" to be self-cleaning. However, from the pics it appears that the slope of your ground is at least 2 and maybe 3 times that grade (i.e. about 5 to 10 degrees). That type of flow is gonna cut into the ground and wash away everything. A lined ditch or channel would be a good solution. Asphalt liner is cheaper than concrete. What is there is not working too well. The comment about flash floods and heavy rains is a smokescreen IMHO.
    Oct 2003
    Afhaggisland
    Charlie,
    Wait till I post pics of my 'MOAT'. I will have Chris download the photos soon.
    Saorsa gu Brath
    (Freedon Forever)
    Μολὼν λαβέ
    "THE BLACK BOMBER"
    Ocklawaha, FL
    Quote Originally Posted by Bluerauder
    That is one reason why I moved to Omaha. When I lived in Waldorf, MD I had to commute to Reston every morning,...1 to 1.5 hours each way.
    Now I get upset if it takes me more than 15 minutes to get to Offutt AFB.... I can see the end of the runway from my deck.
    03 Marauder 300A/Black
    Born: June 21, 2002 / Adopted: April 2003
    Spoiler / Heated Seats / 6-CD Changer
    LIDIO Tuned
    K/N Air Filter
    WILWOOD Brakes
    METCO Control Arms
    ADDCO Rear Sway Bar
    Real Gauges
    INFINITY 572.5cf
    two-way KAPPA series speakers
    NITTOs
    2014 VW Touareg TDI Executive
    2013 F350 King Ranch Crew Cab Dually
    6.7L POWERSTROKE
    Quote Originally Posted by jabird56
    I was at Offutt AFB one night for 3 days !! Darndest freak snow storm that I have ever seen. January 1975.
  1. Why the cooling mod is important
  2. Drivers door holding water??
    By baltimoremm in forum Shop Talk
    Last Post: 03-31-2006, 02:33 PM
  3. Replies: 2
    Last Post: 03-13-2006, 07:52 AM
  4. I'm on my third water pump!
    By Fourth Horseman in forum Shop Talk
    Last Post: 06-08-2004, 08:17 AM
  5. Water Temp Sending Unit Gauge Location???
    By schuvwj in forum Shop Talk
    Last Post: 05-13-2004, 06:18 AM
