Results 1 to 15 of 25
Thread: Trunk lid panel!!
    Mar 2013
    Southwest Florida
    Trunk lid panel!!
    I am looking for the trunk lid panel that bolts to the actual trunk lid. It is the trim panel that the backup lights are attached to. If you don't have one for a Marauder, I would strongly consider one for a Crown Victoria Police Interceptor or LX Sport (LX Sport in black preferably).
    Thanks!
    Smoke Cloud
    You should still be able to get them from the dealer.
    The KING of BLING!
    BOOST GETS YOU IMPERSONATED!
    Mar 2013
    Southwest Florida
    Hmmmm. I will check into that. But, I would guess they would be fairly expensive, especially after you factor in paint, too.
    marauder specific ones, I'm not sure are still avail. CVPI and CV are..not sure about sport models..They do come painted already but the CVPI ones..they are black plastic and not painted adn I wanna say (as I looked into once a few years ago) they range inprice from nearly $300 to $500 pending paint and if trim is painted or chrome. BUt worth a look thru tousley or tasca ford online and maybe a call to your dealer. It's called a rear panel or reflector panel I believe.
    I found one on tascaparts.com for 04 cv..$287.00 but it does not give a specific color or a choice
    May 2009
    Moreau Island
    Try your local junkyards.
    Mar 2013
    Southwest Florida
    That's just it, these are hard to find around here!!!! I found one Crown Vic Sport that has a red panel on it that the bottom trim piece is coming off. Don't look too hard to glue back on and then paint black. That yard is asking $35. But, the trunk is closed and they don't have the key.
    Oct 2011
    Tulsa
    All the ones for the MM are discontinued and zero on locator...all colors
    8w7z13a565aa CVPI
    9w7z13a565ea monochrome(sport)
    Are available, $451 and $576 respectively...retail that is
    I would think there would be quite a few CVPI ones at salvages tho, probably cheap if you found one at a pull a part
    Sent from my iPhone 5
    2003 MM 300B BLACK DARK CHARCOAL INTERIOR
    BUILT 1-9-03
    4.10S K&N CAI MO-TUNE
    Nov 2006
    Union City, CA
    Quote Originally Posted by rocky View Post
    8w7z13a565aa CVPI
    Ditto. Discontinued. None available. Remember that any CV or GM should work but they do not have the Marauder specific tinted backup lights.
    Aug 2010
    Holiday, Fl
    GM one is all reflector. You have to get on off of a CV.
    Stock & Slow
    Oct 2011
    Tulsa
    Quote Originally Posted by 04clone View Post
    Yep need a vic one
    BUILT 1-9-03
    Mar 2013
    Southwest Florida
    Yep, anything is better than this:
    Sep 2005
    APPLE VALLEY,CA
    Mine was replaced under warranty because the bottom of it came seperated. They come color coded from the dealer. They do not need to be painted. Make sure you line up the key hole properly.
    Oct 2011
    Tulsa
    Quote Originally Posted by sflrainmaker01 View Post
    Yeah
    Gross
    BUILT 1-9-03
    Mar 2013
    Southwest Florida
    Yeah
    Gross
    Gee, thanks!
    I have called or visited every junkyard within 50 miles and no Crown Vic panels to be found? I find that unbelievable....
    Oct 2011
    Tulsa
    Gee, thanks!
    Well...
    And usually they go with the deck lid so may be hard to find
    Did find one on eBay from heritageautoparts look under "crown Victoria tail light lid mounted"
    65 bucks
    Also for 199 is a new one for lx sport from NEATCOLLECTIBLES "ford crown Victoria lx sport rear back up trunk license plate panel
    That one looks good!!!
    BUILT 1-9-03
  1. For Sale MM Gauge cluster & MM trunk lid light panel
    By bigcowl-imp in forum Marauder-specific Parts for Sale
    Last Post: 08-21-2012, 06:31 AM
  2. For Sale Marauder trunk lid light panel with harness
    Last Post: 06-08-2012, 05:42 AM
  3. debadge trunk lid
    By LANDY in forum Shop Talk
    Last Post: 09-03-2009, 05:03 PM
  4. Trunk lid liner
    By whoskal in forum Community Discussion
    Last Post: 07-21-2006, 06:04 AM
  5. Trunk lid dynamat.....
    By magindat in forum Community Discussion
    Last Post: 05-02-2006, 12:02 PM
