Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: 2003-2004 Marauder bulb sizes
    Interior and Exterior bulb sizes
    Headlight – 9007 (2)
    Fog Light – H1 (2)
    Rear Stop Light / Turn Signal – 3157 (4)
    High Mounted Stop Light – 912 (2)
    Front Map Light – 168 (194) (2)
    Rear Light (long overhead console) - 42mm Festoon (1)
    Glove Compartment – 168 (194) (1)
    License Plate – 168 (194)
    Trunk Light – 2122 Festoon
    Underhood Light – 906 (2)
    Parking Light - 3157NA (amber) (2)
    Vanity Mirror – 29, 30 or 31mm 6641 (4)
    Rear Reading Light – 45mm Festoon (2)
    Front Foot Well – 168 (194) (2)
    Reverse - 3156 (2)
    NOTE: You can substitute a 194 bulb for a 912, 168 or 906 bulb.
    Adding Cornering lamp - 3156 (qty 2)
    north nj (Planet Houston)
    volt gauge - 168
    oil gauge - 168
    Not that it matters but since some may want that pedantic stock feeling , :
    my map lights were 906s
    dome light was - 578 (which is the same as the 212-2 festoons)
    rear readings - 211-2 (but my trunk was a 212-2)
    Nov 2006
    Ogden Utah
    Don't forget...
    Dash Gauge cluster - Six 194 bulbs
    Shifter - One 194 bulb
    2003 300A
    Build date 9/27/02
    Sequence# 5244 of 7839
    I have a few things done to it, Eaton swap next!
    1993 Ford Taurus SHO-Every bolt on available...Awaiting a Turbo
    2008 Ford F350 SD
    1974 Ford F350 SCS
    2011 Ford Flex Titanium, Ecoboost
    www.cardomain.com/id/shofast
    If you don't stand behind our troops; please feel free to stand in front of them!
    for the dash, i made this:
    so not only 6 illumination but if you are crazy, 10 more for the signals.
    the little blue ones ctrlraven thinks are t5s.
    I haven't pulled it apart yet.
    Jul 2014
    NY
    Quote Originally Posted by the fat bastid View Post
    This is terrific! I have been looking for something like this for a while!
    Aug 2010
    Gadsden, Al
    Good info
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Nov 2006
    Ogden Utah
    That is awesome! Good work, I never swapped my signal lights.
    2003 300A
    Build date 9/27/02
    2008 Ford F350 SD
    1974 Ford F350 SCS
    Headlight Switch - T4 Tall (if replacing with an LED bulb)
    Shifter - 168/194
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    What is the part number for the upgraded LED bulbs inside the digital HVAC head unit?
    There are no "replaceable" bulbs as they are soldered in.
    I solder individual LEDs in place of the incandescent "wheat" bulbs for the buttons and I install an LED for the fan control wheel.
    There is no "replaceable" bulbs as they are soldered in.
    The older digital board bulbs are soldered in place nearest the faceplate side, but I have 2 newer with removable bulbs in the face plate.
    They look like T5 bulbs that you can take out from the back side.
    I did not know there are 2 designs until last night. When you put LED bulbs in these are you doing white or green? I want to do 3 of my marauders this weekend.
    Thank you
    Thank you
    Every single one (probably well over 100) I've done has had soldered bulbs.
    I can do either green or white LED's.
    Thank you
    It would be interesting to see what the Ford P/N is on your EATC's.
    To my knowledge if your EATC bulbs are like this:
    And the solenoids are like this:
    Then you have an older EATC or an F150 EATC (yes they are the same and it's a BI**H to replace the o-rings but it can be done).
    If the bulbs are soldered in and the solenoids look like this:
    Then you have a newer unit.
    In any case, I can repair them all.
    Ok cool. So in your opinion, which LED looks better? White or green?
    Ok, just opened both. Mm has solder lights, the one I repaired last night has removable light bulbs????? LOL. It's was in a 98 GM but the head unit is a 2005??
    Thoughts?
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. 2003 Marauder - Minnesota
    By crouse in forum Third Party Ads (Craigslist/eBay)
    Last Post: 10-06-2016, 02:19 PM
  2. For Sale 2003 Black Marauder for sale
    By lamont76 in forum Marauders for Sale
    Last Post: 10-02-2016, 11:47 PM
  3. For Sale 2003 Mercury Marauder with 83,000 miles - asking $6900
    By RSW in forum Marauders for Sale
    Last Post: 09-20-2015, 01:22 PM
Tags for this Thread
