https://www.youtube.com/watch?v=tZmd7k33JWE
Rather interesting......
Cool! thanks for sharing this. It shows you what a rabbit hole you can fall down into if you have as an opening statement:
"I want to use the engine as a rotating mass in lieu of having to use a flywheel..."
Very interesting design!
Just gotta watch your fingers & hands when setting the timing!.....
Rotary engines are funny things...
I know sometime in the 20's they made a motorcycle with a little 5 cly rotary in the front wheel.
Im a gearhead with way too many vehicles...
Im here to talk about my 03 Marauder. 300A/B (I have a weird mix)
165k miles as of dec 2018
Jmod, removed 2 springs
flomaster
tint and 2din headunit + bigger sub
