Results 1 to 4 of 4
Thread: underdrive pulleys
    Smyrna,Ga
    Question underdrive pulleys
    What are the torque specs on both pulleys to be tightend to crank? waterpump?
    bm'03, I'll look in the service manual when I get home from work, if no one has the answer before then...didn't want you to think we were ignoring you...
    Aug 2003
    Auburn, CA
    Quote Originally Posted by bigmerc'03
    Four bolts holding on the water pump pulley: 25 Nm (18 lb-ft).
    Crankshaft pulley bolt: "Install the bolt and washer. Tighten the bolt in four stages. Stage 1: Tighten the bolt to 90 Nm (66 lb-ft).
    Stage 2: Loosen the bolt one full turn.
    Stage 3: Tighten the bolt to 50 Nm (37 lb-ft).
    Stage 4: Tighten the bolt an additional 85 to 95 degrees.
    So sayeth the shop manual.
    Smyrna,Ga
    thank alot!!!!!!!!!!!!!!!!!
  1. underdrive pulleys
    By RAUDER in forum Shop Talk
    Last Post: 07-21-2004, 05:05 AM
  2. Underdrive Pulleys for Supercharged Cars?
    Last Post: 07-11-2004, 06:18 PM
  3. Raising Idle Speed with underdrive pulleys and Mezeire pump
    Last Post: 07-11-2004, 06:11 PM
  4. Underdrive Pulleys
    By hitchhiker in forum Community Discussion
    Last Post: 02-13-2004, 01:24 PM
  5. Steeda pulleys
    Last Post: 12-13-2002, 07:27 PM
