Results 1 to 15 of 18
Thread: gas pedal sticking
    Jul 2010
    CT
    gas pedal sticking
    recently i have noticed my gas pedal is starting to stick pretty bad off idle. i've tried a few different lubes trying to get it to go away but i think it might be worn out. when you come off idle it sticks so by the time you've put enough pressure to get it moving the engine spikes to about 1500 to 2000 rpm. parking lots and in and out of the garage are getting dangerous having the car launch like that. i can get a new one for about 150 but i wanted to check to see if there were any tricks i might not know about first.
    my other problem is how do i tell if my pedal has memory? it's adjustable but i'm not sure what they mean by memory or how to tell the difference.
    Apr 2005
    Queens NY
    Quote Originally Posted by russell072009 View Post
    Sounds like you may have melted the cable on the EGR tube. You'll have to replace it if it sticks, no way around it, I tried on my GF's car when her's melted and after wasting a hour, it was just easier to get a new one and move on.
    The pedals on my car at least, are not memory. I just set them and they never move from that position.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    Jul 2010
    CT
    you think it's a cable issue? i figured it was the pivot point inside the car.
    Apr 2005
    Queens NY
    Simple way is remove the cable off the pedal check the play on the pedal itself. Or remove the cable off the TB and hold it straight out and see if you can move the pedal. If its sticking like that, Im pretty sure its a cable issue.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    My wife's did that, cleaning the throttle body and a little WD40 on the cable & linkage fixed it.
    No memory on pedals or seats.
    Jan 2008
    +34 Dg 32' 39" X-82 Dg 40' 24"
    Mine has always been a little sticky, worse in cold weather, I just give it a little tap with my foot, and then add the throttle, it was fun getting use to it at first.
    "A street walking cheetah, with a heart full of napalm."
    "If You can keep Your Head About You, While Others are Losing Theirs and Blaming It on You..."
    "Sometimes it is wiser to remain silent, and seem a fool, than to speak, and remove all doubt."
    "We've been looking for the enemy for some time now. We've finally found him. We're surrounded. That simplifies things."[5]
    Apr 2007
    Quote Originally Posted by fordnut View Post
    my wife's did that, cleaning the throttle body and a little wd40 on the cable & linkage fixed it.
    +1^^^^^^^^^^^^^^^^^^^
    Excess in Moderation.
    Sprinkles are for winners.
    Apr 2005
    Queens NY
    The OP said he already tried lubing it and it didnt work.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Aug 2010
    SE Virginia
    I've seen two Ford throttle bodies that had the stick issue at rest(neither were Marauders)... In both cases, I slightly adjusted the base idle set screw till it would not allow the throttle blade to fully shut and stick in it's bore, never any issue afterward... In my cases the adjustment was less than 1/4 turn...
    45Kmi - Eaton SC - 430RwHp - SOLD!!!!
    Jan 2010
    new jersey
    It's a dirty throttle body
    Aug 2010
    SE Virginia
    ^^^^^^ Cleaning would not fix the ones I had problems with...
    Quote Originally Posted by YOCKIT View Post
    Agreed.
    Phoebe had the EXACT same issue as the OP and the throttle body behind the blades was all gunked up. Used CRC MAF cleaner and a few Q-Tips and no more stick.
    As for the pedals and seats, they are manual only...no memory.
    Oct 2009
    Belle River, ON
    My car has the same issue. I thought it was the gas pedal sticking, and sprayed lube all over the place, before realizing it was the throttle body, like other guys have mentioned here.
    Trouble is, I clean it, and it only works good for a month or so, then the sticking comes back.
    Belle River, Ontario, Canada
    2003 Marauder - Black
    Car #5636 of 7839
    Lidio Tune, K&N CAI
    Nov 2010
    Silverton,OR
    Mine has the same problem, only happens in colder weather. Goes away when i spray some lube on the pivot point on the gas pedal (only last a couple of weeks). Is there a bushing that can wear out on the pedal assembly?
    Friendswood, TX
    +1 on cleaning the throttle body. Gunk buiilds up and the blade is hard to open from the completely closed position. $5 for a can of throttle body cleaner and 30 minutes and you'll be good to go.
  1. Sticking accelerator pedal
    By sconut1 in forum Shop Talk
    Last Post: 01-12-2011, 09:18 AM
  2. Gas pedal
    Last Post: 07-20-2010, 10:51 AM
  3. Gas Pedal
    By Mike827 in forum Shop Talk
    Last Post: 05-11-2010, 04:26 AM
  4. Sticking Accelerator Pedal
    By nelsonrock in forum Shop Talk
    Last Post: 02-02-2010, 10:56 AM
  5. Gas Pedal?
    By ezratty in forum Community Discussion
    Last Post: 04-29-2006, 05:47 PM
