Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Compression ratios
    Apr 2010
    Denver, CO
    Compression ratios
    So I'm doing a bunch of maintenance work getting ready to supercharge my MM. I'm going to be replacing timing chain and tensioner because it's about that time and was thinking 10.1:1 compression ratio seems wayyy too high to just throw a supercharger on it. Most supercharged applications are 8.5:1 if not lower. Now somebody correct me if I'm wrong, and I seem to be since a good portion of marauders are supercharged now doesn't that seem like a ticking time bomb?
    2003 MARAUDER
    Lidio Tune
    JLT Intake
    Aero Turbine 2525 mufflers
    No 2nd cats
    Resonator Delete Tips
    NGK TR6 Plugs
    180* T-stat
    Quote Originally Posted by MMarauder03 View Post
    you can run boost with 23:1 compression just like diesels. idealy yes you would want lower compression on a gasser but you dont HAVE to have it. you just compensate for it in the tune and amount of boost you run.
    Apr 2010
    Denver, CO
    That's what I was thinking, well if I were to bore my stock block .020 over since it does have 115k, forged pistons and crank. Now there are manley pistons with a 23cc dish that would put a 4valve 4.6 at 8.06:1. Would there be any qualms about boosting the piss out of it? Obviously with supporting mods
    2003 MARAUDER
    Lidio Tune
    JLT Intake
    No 2nd cats
    NGK TR6 Plugs
    180* T-stat
    im no expert when it comes to this stuff but that seems low. i would bore it min amount possible if its needed at all. boring a motor to get more cubes on a street car is just stupid IMO. iirc stock cobras run about 8.5:1 CR. hell i pumped 14psi into my stock engine and fed it the full 14 every chance i got and so does the new owner.
    if i were you and you are going into the engine regardless, id go 8.5ish with good forged rods and pistons and call it a day.
    if it were me, id feed that ***** like it sits and buy stock in rubber, these motors are stronger then most give credit. they only fail when people do stupid things or push them beyond what is considered "safe"
    I'd stay at a 10:1 compression. Unless it's a track car and you're going to pack in 20+ psi no reason to lower it.
    Apr 2010
    Denver, CO
    Quote Originally Posted by SpartaPerformance View Post
    Thanks sparta and dave. Looks like you guys saved me a ton of money! Now to throw 2,000 in my supercharger fund. I'm almost there
    2003 MARAUDER
    Lidio Tune
    JLT Intake
    No 2nd cats
    NGK TR6 Plugs
    180* T-stat
    np, i was a little nervous about putting boost to the stock motor but with a good tune you got nothing to worry about as long as you dont go attempting to make 500hp.
    Apr 2010
    Denver, CO
    The plan is to tide me over until i get an aluminator or build my own. Just tired of being slow
    2003 MARAUDER
    Lidio Tune
    JLT Intake
    No 2nd cats
    NGK TR6 Plugs
    180* T-stat
    i bet you will have an aluminator and will be wondering why the hell the stock one wont blow up lol
    I went with 9.5:1 cr
    Apr 2010
    Denver, CO
    LMAO, hopefully!
    2003 MARAUDER
    Lidio Tune
    JLT Intake
    No 2nd cats
    NGK TR6 Plugs
    180* T-stat
    Oct 2008
    Ocala, florida
    Put the blower on it first, when the stock engine blows up build a motor around 9.5;1 CR.
    Done deal
    Dec 2008
    South Carolina
    Would you need headers for this upgrade
    Adopted 3/31/11. Sold
    03 300a black #1199
    TERMINATOR SWAP
    430rwhp. Done by mo's
    Oct 2004
    Depending on type of headers they would give you another apx 50 hp.
    Dec 2008
    South Carolina
    Wow 50hp from headers after forced induction. In that case it's worth a grand for headers
    03 300a black #1199
    TERMINATOR SWAP
  1. 4r75 gear ratios
    By ImpalaSlayer in forum Transmissions
    Last Post: 10-07-2010, 04:10 AM
  2. Tires and Axle Ratios
    By Peace2Peep in forum Community Discussion
    Last Post: 11-02-2008, 08:10 AM
  3. Compression anyone?
    By Motorhead350 in forum The Lounge
    Last Post: 05-14-2007, 04:43 PM
  4. 4r75w drive ratios?
    By BigCars4Ever in forum Shop Talk
    Last Post: 04-07-2006, 05:54 PM
  5. Gear Ratios?
    By Reaper948 in forum The Lounge
    Last Post: 04-18-2003, 12:09 PM
