Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: SW headers, N/A cars - dyno tune or nah?
    Jun 2008
    I'm considering martyo's Black Friday deal on SW headers for the Marauder. Since I'm N/A with a Zack tune and probably will stay that way for a good while, I was going to buy the catted headers with the factory exhaust connection.
    I've done some reading on the forums and I'm getting conflicting information, or maybe I'm just getting myself mixed up. Some posts indicate a possibility of a lean condition after the header install, other people say it's fine and the car simply won't be 'maximized' in terms of HP.
    Also seeing folks fighting with the EGR - how bad is that?
    Talk to me.
    I don't think you need a Dyno tune, 2mercs has a SW system and he doesn't have a Dyno tune. You do need a tune as the O2 sensor is further away. Check engine will appear. 2mercs fought with cel for a bit, I think it got straightened out
    Aug 2016
    Montgomery, AL
    I have a full SW system no Dyno tune. Marty did my install and tune.
    Dec 2013
    NE Ohio
    Marty turned off my rear 02s. Think they installed the wrong ones at stainless works. If you're worried about install they offer that service at a flat rate I'm pretty sure.
    Jun 2008
    I'm not sure I understand. If the car already has O2 sensors, and they're in a different location (farther away) that would render the tune I already have obsolete?
    (like I said, I'm f'n confused on this, haha)
    Apr 2010
    South Florida
    Get the Headers and a new file from Marty. I deleted My EGR because the installer cracked it. Causing a rough, hot start.
    Quote Originally Posted by a_d_a_m View Post
    yes, pretty much..the O2 sensors are further back and changes the values/parameters. Best to send Marty a pm for better info
    Be prepared to buy a new Xcal as I’m assuming the Zack tune is on an Xcal2.
    Maybe ask Zack first as he may have already tweaked it for headers.
    Plenty of WD40 on the EGR. I’ve yet to break/crack a tube.
    PB Blaster FTW!
    Apr 2010
    South Florida
    PB Blaster FTW!
    I use Buster! Try it out.
    Jun 2008
    Makes sense.
    Yeah, it's an old X2, had it since 2009. Don't think it's tweaked for headers...could be wrong.
    Thanks for your input, everyone!
    To spend the coin on LT's and not do a tune, seems counter productive to me, just my 4.6 cents. YMMV
    Trilogy # 192 / T.S. 0012
    Jun 2008
    I don't have the money to drop on headers AND a tune, especially around this time of year. It's not that it won't happen, just wouldn't happen right away. In the meantime, the sound would be a nice addition...
    Oct 2014
    Charlotte, NC
    What motor mods are recommended for a NA car to take full advantage of a complete SW system?
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    Hiram, Georgia
    No additional mods are needed to take advantage of the system.
  1. Headers/Cat Delete/Tune
    By MarauderPU in forum Tuning
    Last Post: 05-11-2013, 04:05 PM
  2. Dyno Tune after headers
    By kmastl in forum Shop Talk
    Last Post: 07-17-2010, 04:35 AM
  3. FRPP Shorty Headers 4.6 4V Cobra Dyno Test
    By Glenn in forum Exhaust
    Last Post: 03-07-2010, 09:10 AM
  4. Kook's Headers Dyno Results!!
    By Logan in forum Kook's Custom Headers
    Last Post: 08-31-2006, 09:44 AM
  5. Walker Dyno Tune - Interested in a Dyno Day?
    By Donny Carlson in forum Southern Marauders
    Last Post: 03-03-2005, 09:08 PM
