Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Thread: Difference: MM Engine & Mach1 Engine
    Does anyone know the differences between our engine and an engine from the Mach1? They are at over 300 rwhp with just a K&N drop in and some exhaust work.
    One thing I know is the air intake faces left in the Mustang, and to the right on ours.
    ..also,.. I'm not sure if the Mustang has an aluminum block like ours.
    I'm sure someone will shed more light on this...
    Connecticut
    Quote Originally Posted by Petrograde
    Yes, they do have aluminum blocks. The mach I's also have the alternators mounted in the middle like our Marauders do. They also have the same compression ratio, but that's all I know. I'm not sure about piston type. But the cranks are the same too. This is a good question this thread brought up. Anyone else have more info?
    Nov 2003
    Northern California
    They've got a big ass intake on top of the HOOD!
    It's a big help I'm sure.
    Washington DC
    I believe the manual transmission has a steel crank, and the auto is cast.
    Merc's Garage
    Nov 2003
    Northern California
    Quote Originally Posted by merc
    AND, It has a manual.
    Nov 2003
    Northern California
    I guess Mach 1's are pretty cool then.
    I don't mean to sound like an ass.
    Connecticut
    Okay, thanks for that correction Merc.
    Quote Originally Posted by woaface
    Yes but they also have an air intake tube just like we do. I was just informed they believe it is the drivetrain loss with an automatic, since their autos come in around the same power as ours but their manuals are usually 40-50 rwhp better.
    Connecticut
    Are you saying that there aren't any Mach I's equipped with an automatic?
    Another dfference is the Mach1's engine is hand assembled. Maybe it's balanced better??
    Oct 2004
    MO
    But not as cool as my Bullitt. . .
    or Mackensie. . .
    ncmm
    '04 Silver Birch MM 300A, build date:03/11/04, bought new 10/04 traded 8/08, 27k miles,
    '04 Silver Birch MM 300A, build date:12/23/03, bought used 3/16/12, 24k miles
    113k miles as of 8/21/19. . .
    update. . . sold 11/5/2019, 116k miles
    Visit My Old Gallery
    They both have tin foil blocks... Cast iron what it's all about.
    Connecticut
    Quote Originally Posted by metroplex
    Are you saying that only because they're aluminum?
    Washington DC
    An Iron block is a good practical design for strength and durability. On the down side of that it has the extra weight and heat dissipation problems. In other words.. its heavy and doesn’t get rid of heat fast enough. For applications with superchargers you need a good bottom end if you desire to force a lot of air into the system to achieve grunt horse power, an Iron block is ideal if you want it to stay together. But an Iron block is not always better. Aluminum blocks are lighter in weight and dissipate heat quicker, which should allow the engine to work more thus freeing up extra horse and torque. In applications of racing sometime a cooler running engine can be ideal for consistent 1/4 mile times with out having a heat soaked engine, besides the fact that it doesn’t have the weight where as the Iron block would have to work harder. We all know that weight and heat effect 1/4-mile times and the aluminum block provides another option to achieve better times. There are advantages and disadvantages to both designs however. It really comes down to what application you desire and personal preference
    Merc's Garage
  1. Hole in block
    By MarauderMark in forum Community Discussion
    Last Post: 12-19-2004, 05:43 AM
  2. Biggest Engine In The World - 108,000 Hp!
    By Directedby in forum The Lounge
    Last Post: 12-09-2004, 10:25 PM
  3. Marauder needs a new engine. Options?
    By Fishman in forum Shop Talk
    Last Post: 09-05-2004, 03:39 PM
  4. Wierd engine miss???
    By junehhan in forum Community Discussion
    Last Post: 04-04-2004, 08:26 PM
  5. The Prowess of the V8 Engine:
    Last Post: 01-15-2004, 03:41 PM
