Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Thread: Trip to track after 4:10 gear swap.
    May 2016
    T-Town
    What a disappointment. Lost .01 of a second. Yes. Actually ran slower in the 1/4.
    Picked up .162 in the 1/8th. Whoop de freekin' do!
    Is something not right? There was a strong headwind all night or maybe I gained a few pounds but never would have imagined.
    Aug 2012
    Kansas City
    Quote Originally Posted by Jtrip View Post
    Post before and after timeslips to be able to figure out what the issue is..................
    Neil
    2003 Mercury Marauder - SB/LF
    May 2016
    T-Town
    Quote Originally Posted by 8UWITH6 View Post
    First pic should be fastest run before.
    Second set of slips are from tonight.
    Oct 2014
    Charlotte, NC
    Was your car retuned for the new gearset? In dreamland, I’m considering 4:10 gear set, 3500-3600 stall converter and CAI - keep in mind our stock engine torque peaks at 4250 rpm. Stock stall for my ’04 is between 2500-3000 rpm - let’s just say 2500 for this scenario. The car will have to be retuned to make it all work.
    I’ve had no dealings with MartyO on this board but he has many positive references here. Tell him what you have and he should be able to mail you what you need.
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    May 2016
    T-Town
    Was your car retuned for the new gearset? In dreamland, I’m considering 4:10 gear set, 3500-3600 stall converter and CAI - keep in mind our stock engine torque peaks at 4250 rpm. The car will have to be retuned to make it all work.
    I’ve had no dealings with MartyO on this board he but has many positive references here. Tell him what you have and he should be able to mail you what you need.
    I bought a tune from him with a 3:55 and 4:10 option. Not sure what difference it would make besides the speedometer. I switched it over. Maybe I did something wrong. My MPH has dropped in the 1/4 but I assume that is because of the gear swap.
    Oct 2014
    Charlotte, NC
    Fuel, spark and transmission maps should all be different, along with the speedo correction. Hmmmm….
    Current Garage:
    William W. Purkey
    Check the density altitude of both days online, I bet the DA was better in June last year.
    You can check the DA of the track back a few years. Wallace racing might have the calculator, i forget.
    Can you add more timing in first gear? That sixty foot is terrible
    Hth
    Jul 2015
    Georgia
    Put a converter in it.
    Your better run a few days ago at 6:22pm, the DA was Density Altitude: 426 feet
    Relative Density: 98.76 %
    Your timeslip from June 24 2017, the DA was Density Altitude: 2366 feet
    Relative Density: 93.26 %
    Read more: http://www.dragtimes.com/da-density-...#ixzz5DPXHuWnB
    OK, so something is seriously wrong with your car. It should have went much faster with the lower DA... I would ask Marty to chime in. With the above information, he will see that something is not correct. The car should have more HP with lower DA. This is the MPH at the 1/4 mile mark. Your down a few MPH.
    So your lacking HP. What gasoline do you run?
    May 2016
    T-Town
    Sorry bro, you can keep a knockin' but you can't come in.
    "Zeph78
    This message is hidden because Zeph78 is on your ignore list."
    May 2016
    T-Town
    Thanks. I will.
    "Premium fuel only"
    Jul 2015
    Georgia
    It's alright J I'm not here to derail your thread like you did mine. Just to share some real world experience with the two Marauders I own.
    My newest Marauder has the same mods that you have done and like you, I wasn't impressed with it. My old Marauder had a 2800 stall converter and the difference was night and day. These are small cube engines in heavy cars with tight converters from the factory. These engines also like rpm and the factory converter won't let the engine get moving before the car does. I chose a 2800 stall FTI converter because it was cheaper than the 3000 stall that's more popular. I think you would really be impressed by how much of a difference a good stall converter makes in these cars. Another good thing is they're way cheaper than a set of sw long tube headers and exhaust. Just going from a 3:55 to the 4:10 isn't much of a difference, but when coupled with a good LU stall converter it's much better. Good luck with whatever you decide to do. I'm going to swap things over from mine one at a time to see what difference each mod makes.
    Jun 2012
    Grand Rapids
    Something is up... my stock car would only run 15.1.... 4.10 gears and tune she dropped to a 14.5... is your car stone stock other than the gears and tune? 14.80's on a stcok car is really quite good but that 60' time is junk...
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Jul 2015
    Georgia
    Quote Originally Posted by Curless View Post
    So you went a 14.5 with a gear and tune which is what I think he has, and he went a 14.8? What mph and 60' did yours do?
    May 2016
    T-Town
    CAI, Marty's tune, 4:10's that's it. No tire spin either.
  1. Marauders first trip to the track
    By Fly007 in forum Community Discussion
    Last Post: 08-29-2016, 04:52 PM
  2. The trip to Gear Heads Performance
    By -Matt- in forum Shop Talk
    Last Post: 06-04-2010, 08:24 AM
  3. MM 1st trip to track
    By swordfish in forum Drag Racing Round-up
    Last Post: 11-21-2009, 07:50 PM
  4. Marauder's First trip to the track
    By Eric91Z in forum Community Discussion
    Last Post: 10-17-2005, 08:50 AM
