Results 1 to 10 of 10
Thread: Pulling trans with LTs
    Nov 2006
    Bridgeview, IL (near chicago)
    Question Gents,
    I am pulling a trans in a 03
    Can you get the starter off without pulling the LT Headers? As well, can you leave the headers in and drop the trans straight down if there is no H pipe?
    Just wondering for information before I go dropping this thing.
    Would be nice to have an easy time doing so.
    Jun 2008
    Waukesha, WI
    You can do both with Stainless Works headers
    Nov 2006
    How about Kooks?
    I hear the starter with Kooks is either no go or is very difficult..I have no direct experience
    The starter will come out with either brand of headers.
    Starter with Kooks is a PITA....
    First ...good luck with the upper bolt...
    Then: Flip it, turn it, twist it, spin it, bang it, drop it, and finally curse it.
    Jun 2007
    Whitehall, PA
    Quote Originally Posted by cvpiftw View Post
    How about Kooks?
    The trans will come out with Kooks headers. The biggest issue is the starter. Make sure the battery is disconnected, remove the bolts to the starter and leave it between the block and the headers.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    Warson Woods, Missouri
    kooks & starter
    what joe said: curse, twist, pound, pry, cry & it pops right out
    Feb 2017
    New Orleans, LA
    the top bolt is easy to remove, you use a small socket and a long extension, feed it above the starter and its the perfect length then clip the ratchet on it and remove it very easily. Its all in the feel can't see it.
    Jun 2008
    Waukesha, WI
    I agree! But I still left mine out.
  1. Pulling the 4.6..need some simple help
    By tumbler33 in forum Shop Talk
    Last Post: 10-16-2016, 02:21 PM
  2. Pulling my engine
    By kirk in forum The Classic Lounge
    Last Post: 06-18-2016, 12:07 PM
  3. Still pulling strong :)
    By ludwigvan968 in forum Community Discussion
    Last Post: 01-11-2013, 03:08 PM
  4. Pulling off Tires
    By murphypeople in forum Tires & Wheels
    Last Post: 03-15-2007, 07:09 AM
  5. Code pulling
    Last Post: 05-09-2003, 12:45 PM
