Results 1 to 15 of 19
Thread: Nitto NT 555's???
    Oct 2003
    Beaufort, SC
    Nitto NT 555's???
    I am going to order Nitto NT 555 tires and wonder what the rev/mile differential should be to keep the TC and ABS happy??
    Mac runs 245/45's up front and 255/45's out back and rev/mi difference is 13....with 255/45's out back and 235/40's up front the rev/mi difference is 51!!
    What are the upper and lower limits of the difference before the computer goes wackey??
    Thanks,
    Marauderjack
    Oct 2003
    Beaufort, SC
    Hellooooo..........Anybody out there??
    I guess any rev/mile difference will work but I would like to be sure before I order the tires!!
    Marauderjack
    This is what I would do if I had stock rims for the back. Since I have widened rims, I use the 255/45's on the front and will be switching between 295/45's and 305/45's on the rear.
    Oct 2003
    Beaufort, SC
    FordNut....
    Will a differential of only 13 rev/mile be enough?? The stock tires have a differential of 35 rev/mile???
    Thanks,
    Marauderjack
    BANK OF BANKS CREEK
    deleted because of not reading afore post,...willie
    2003 Marauder BLACK
    SS inserts
    Addco sway bars
    JLT CAI
    4.10's
    MO's custom tune
    275 rwhp/303 lbs. torque
    Quote Originally Posted by prchrman
    So 255/45s will fit on regular MM wheels on the front with no rubbing?
    willie
    Yes. That's what the KDW2 users are doing. And I believe that's what Glenn used when he went with the Nittos too.
    Aug 2004
    Maryland
    I did not notice a change when I went with the wide rims and Nitto DR. If it ever stops raining here, I'll get my speed checked with radar and let you know.
    11.98 @ 115 mph
    FordNut....
    Thanks,
    Marauderjack
    I can't say for sure since you have an '04 (traction control) but I believe it will be ok. I do know that the ABS light will come on at extended high speed use with all 4 tires the same size, but with slightly larger rears it should be ok. Hopefully somebody with t/c that has tried different sizes will chime in.
    Aug 2004
    Maryland
    I have an 04. I usually drive with T/C off. I have not see a problem with it on....
    I have a trip to NY coming up, I cruise for awhile with the T/C on to see.
    11.98 @ 115 mph
    Oct 2003
    Beaufort, SC
    DEFYANT....
    What size tires are you running...if not OEM's??
    Thanks,
    Marauderjack
    Quebec city Canada
    Thanks,
    Marauderjack
    The best way to figure out alternate choices with tires is with the link below. Just put your front and rear tires size and check that they met a 5% or higher % difference. Also, i think the computer could accept between about 3 to 5% since it would mimic taking into account the tread usage (of the rears) after a given time. I personnally don't respect the 5% and keep the TC switch at off with no boring side effects.
    http://www.tyresave.co.uk/tyresize.html
    Good luck
    Dec 2004
    Arizona Territory
    DEFYANT....
    Thanks,
    Marauderjack
    I can't speak for DEFYANT but I am running the Nittos with 255/45s on the front and 295/45s on the back. That seemed to be the most common combination (when wide tires were chosen) that I saw at the MVIII in Detroit.
    I have not noticed any problem with them.. tho I only have about 400 miles on them since installation.
    AzMarauder
    Sierra Vista, Arizona
    2003 Marauder 300A
    Black
    Trilogy Supercharger Serial # 105
    Installed 9/30/2005 - 10/6/2005
    2010 Dodge Challenger R/T
    Detonator Yellow
    1967 Ford Fairlane, 428CJ, 5spd, running dual quads.
    Connecticut
    Just so you know, be advised that the Nitto NT555, and the NT555R are two different types of tires, and it's only the NT555R that is a drag radial tire. the NT555 is NOT.
    Aug 2004
    Maryland
    DEFYANT....
    Thanks,
    Marauderjack
    I have the Nitto 305/45R-18 tires on the rears, and stock tire on the front.
    11.98 @ 115 mph
    Oct 2003
    Beaufort, SC
    I guess as long as the rears turn slower than the fronts the T/C will behave itself??
    I have choices between 13 rev/mile difference to 51 rev/mile difference since I don't have widened rims!! The OEM difference is 35 rev/mile.
    If the T/C acts up...I'll turn that sucker off!!
    ABS shouldn't be an issue in any case...should it?? I guess this is true since ABS kicks in when a wheel STOPS rolling.
    BTW....Any of you priced tires lately?? They are going up fast.....In fact I have a friend who says a trailer manufacturer he knows cannot get tires for the trailers he builds (Tracter Trailers).........I guess sooner or later we'll be getting everything from China!! Wonder how we will pay for it??
    Marauderjack
  1. Cold Nitto tires
    Last Post: 11-13-2004, 01:42 AM
  2. A Question about Nitto 555s
    By Petrograde in forum Shop Talk
    Last Post: 06-27-2004, 09:39 PM
  3. Nitto Tire Pricing
    Last Post: 12-31-2003, 03:15 PM
  4. Nitto Tire ?
    Last Post: 12-07-2003, 06:51 PM
  5. Will Nitto 555s in lower series fit?
    By studio460 in forum Tires & Wheels
    Last Post: 10-26-2003, 04:28 PM
