Results 1 to 15 of 22
Thread: Remote Oil Filter Questions
    Mar 2014
    Tampa, FL
    Question Remote Oil Filter Questions
    I'm tired of gettin oil everywhere and havin to clean it up after an oil change. It's hard as H-E-double-hockey-sticks to get to and just a general PITA, as everyone is accustomed to. I'm thinkin about relocating the oil filter when I do my next oil change, which will also be when I change the oil filter adapter gasket. Seemed like a good time to do everything.
    I've read a few old threads here and there about relocating the oil filter using a kit and the general consensus seems to be that the over the counter kits you can get from summit or wherever that use rubber style hosing and barb fittings w/ clamps tend to leak and just be of generally crappy quality.
    So, my questions are: 1) Who has done this project and what results have you had over time?, and 2) What materials has everyone used/what do you recommend?
    I'm on a budget, but I definitely don't wanna go cheap. As a reference, Canton products, while great quality, are a little out of my price range.
    Here's what it seems like it's gonna need:
    SS braided hoses w/ fittings
    Some type of filter adapter for the original plate
    A new remote oil filter mount
    Anything else I'm missing? Thanks in advance.
    2003 Black 300A
    Adopted: 4/26/14
    Mods:
    Mo's Tune - K&N CAI - 4.10 FOMOCO gears - Reische 170* T-stat - NGK TR6 Plugs - Flowmaster 40s - MuscleMerc's 3" Fuel Filter Mod - Addco Front and Rear Sway Bars - TCE SS Brake Lines - Cooper RS3-G1 - Factory Spoiler - SS Bumper Inserts
    May 2006
    Seattle, WA
    Why don't you just get an oil deflector?
    Can't stop the signal
    I have one, braided lines, blah blah blah, took it off, it's only semi convenient in my opinion.
    Trilogy # 192 / T.S. 0012
    Mar 2014
    Tampa, FL
    Quote Originally Posted by Mebot View Post
    Considered it. There are two different kinds though, one seems to be for GM one for MM. Not sure if universal fit for both. Plus, I would have to go through the trouble of taking and putting on/off each time. Would still probably be some type of mess involved. Not to mention, it's not just about the mess. It also has to do with location of filter. Still a pain to get out past steering component assemblies. Depending on where I relocated to, might not even have to put car on ramps to do oil change. Who knows.
    Why so? Interested in all opinions on the matter.
    2003 Black 300A
    Adopted: 4/26/14
    Mods:
    A half of can of brake clean to clean up the oil is going to be cheaper up to 80 oil changes.
    Don't waste your money.
    Hiram, Georgia
    You stole my post!
    True....but the 'gummint' is working hard on outlawing any useful chemical that actually works!
    BrakeClean is first on their list.
    I want my carcinogens at full strength.
    Quote Originally Posted by HotRaud90 View Post
    You install it and leave it alone. Mines been on for many years and every oil change is drip free.
    Builder Of Badassery
    Nov 2013
    CT, MA
    my experience was a Summit deal, TransDapt maybe? A spin on with the rubber hoses to the relocated filter mount. Everything was dry, and pressure great, until 150 miles and my new engine had a rod knock.
    the filter adaptor passages did not fully align and starved my motor of oil. NEVER AGAIN.
    rebuilt the motor, no relocated filter - still running strong with next owner 10 years later.
    2004 SILVER BIRCH/BLACK PAINT
    DARK CHARCOAL NUDO LEATHER
    #400 of 997 (SOLD)
    2004 CV LX SPORT
    2004 300A MM BLACK
    1 OWNER CAR, NO OPTIONS
    DAILY DRIVER
    2013 DAYTONA R/T
    SUPER TRACK PACK
    DAYTONA BLUE PEARL
    #1763 off ~2100
    NOW WITH A 392 & 3.73 posi!
    Oct 2010
    I have a Kit from MMR , but you can easily make your own , i like mines , and its very easy to get to , plus it takes the bigger FL-1A oil filter.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jan 2012
    Richfield, MN
    I just crack the filter loose and let it make it's little mess, then deal with what happens 5 minutes later. Not a lot of oil left to spill after that.
    2003 300A, #5379 of 7838
    Mar 2014
    Tampa, FL
    I saw another member post about how his flew off somewhere along the way. I think it might've been RF Overlord. Went under to look for it and it was gone. Was concerned about that. What part number? As I mentioned, there appears to be two. I'm wondering if there are different mounting clips based on which model it is (whether it's for a Grand Marquis or a Marauder), and whatever steering assembly components they're supposed to attach to.
    Quote Originally Posted by MOTOWN View Post
    I liked the idea of it being vertical. No more spillage? But, as others have been saying, it is more expensive. MMR looks pretty pricey too...
    2003 Black 300A
    Adopted: 4/26/14
    Mods:
    Don't know the number as a member gave it to me. I do know it has two clips and it snaps in really tight. I can't see how it could ever come off?
    Nov 2013
    CT, MA
    guys are posting positive results, some were negative.
    I did like the ease of installing and upright filter position (mine was a dual filter mounted by the radiator for fresh air), but you should pay to get quality. Your engine is worth it.
    #400 of 997 (SOLD)
    2004 CV LX SPORT
    2004 300A MM BLACK
    DAILY DRIVER
    2013 DAYTONA R/T
    SUPER TRACK PACK
    DAYTONA BLUE PEARL
    #1763 off ~2100
    Oct 2010
    Heres a pic of my remote filter
    ITS ALIVE !!!!!!!!
  1. Remote Oil Filter Adapter Leaking!!!!
    Last Post: 11-19-2006, 09:49 PM
  2. Remote oil filter is in
    By BigCars4Ever in forum Shop Talk
    Last Post: 09-19-2005, 05:42 AM
  3. Remote Oil Filter ?
    By FordNut in forum Shop Talk
    Last Post: 02-01-2005, 09:12 PM
  4. Oil Change ? w/remote filter & oil cooler
    Last Post: 07-29-2004, 04:06 AM
  5. Remote Oil Filter
    By grzellmer in forum Community Discussion
    Last Post: 01-02-2003, 08:15 PM
