Results 1 to 12 of 12
Thread: KVR 14" big brake rotors.
    May 2017
    Whitehouse Station NJ
    Well I wore them out and called KVR. Good run of 100K no issues however response, was "sorry we do not carry them any more and can't help you." NO effort to help. Stay away from them. Had no info on previous supplier but was really to lazy to find that out. Any thoughts on replacement rotors that would drop in ? They use C4 Corvette calipers. Hate to spend a fortune on another kit but will if I have to, either Willwood or Baer. Thanks, Stan
    Try a 2010 GT500 Rotor
    Baer no longer makes a kit for marauders. contact member: Curless he used to know where to get replacements
    DBA makes a replacement rotor, but it won't fit the KVR hats. You have to get hats from Baer.
    May 2017
    Dallas Texas
    Baer makes a kit ... they just changed design of the front kit.. you'll have to call
    Jun 2009
    Warsaw, Indiana
    Call Todd at TCE. I have had his 14 inch rotors with 6 piston Wilwood calipers for maybe 5+ years and i think they are the best mod i have done. They will stop one of our not so svelte beasts like running into a padded wall. I have never driven any other vehicle including one with brembos that felt so secure on braking.
    Sent from my SM-G935T using Tapatalk
    Quote Originally Posted by moola94 View Post
    they quit making their big brake kit for 03,04 marauders...what info do you have ?
    Nov 2003
    Monroe, NC.
    Quote Originally Posted by Griso8v View Post
    Hello Stan, Give me a call I have replaced my KVR rotors and also the GT500 Rotors may work you will have to re shim the mounting points. Sent you PM with my phone number.
    Russ
    Russ, Monroe NC.
    Chicago
    I have KVRs. Send a PM to Curless I beleive the rotors are 2004 vette rotors but ask for sure. I knwo the calipers are.
    Steven
    2004 Marauder Black, loaded
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    476.9 rwhp 385 lbs/tq
    Lidio tune
    2004 Suburban Dark Charcoal
    Quote Originally Posted by SteelQualityMan View Post
    +1!
    IMHO... the best mod for a Marauder.
    Jun 2012
    Grand Rapids
    Quote Originally Posted by stevengerard View Post
    Vette calipers, the rotors are almost identical to the GT500 rotors. We got your rotors through a Michigan Manufacturer of racing rotors. They are available just need to know how to go about it. Thats what we did on your car Steve.
    http://www.colemanracing.com/Brakes-C94.aspx
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    May 2017
    KVR 14 inch Rotor service limit.
    Does anyone know what the service limit is for thickness ? New I believe they were 1.25 inches. I may have found a used resurfaced set just want to make sure they are usable before I shell out $$$. Thanks, Stan
  1. KVR brake rotors
    By RubberCtyRauder in forum Steering, Suspension & Brakes
    Last Post: 01-16-2015, 10:05 PM
  2. brake rotors!which ones?
    By tom6687 in forum Steering, Suspension & Brakes
    Last Post: 08-16-2011, 04:11 PM
  3. For Sale Used EBC Brake Rotors
    By crouse in forum Marauder-specific Parts for Sale
    Last Post: 07-11-2010, 06:13 PM
  4. Brake Rotors
    By 281MERC in forum Steering, Suspension & Brakes
    Last Post: 06-07-2010, 01:50 PM
  5. Brake "wipe" on Rotors
    By Dragcity in forum Community Discussion
    Last Post: 07-26-2007, 02:31 PM
