Hello guys,
I am happy to be with you in this wonderful forum
I'm looking for the Marauder 2003 engine not rebuild
Used or new, but it is important to be clean and no problems
So look for a clean engine if it is on a damaged car or other
Hello guys,
What are yiur shipping arrangements going to be?
Shipping will be very expensive. Definitely not $300, just being honest. It can be done though im sure.
98 P71SOLD
export crating min. $500 plus boat ride over, plus freight forwarder fees, guessing $1000-$1500. thats once delivered to a port and dropped off at the Saudi port. not delivered to door. this is not a ups shipment. spend more than motor worth. rebuild it locally
Would this be an option?
http://www.modularmotorsportsracing....roducts_id=389
Maybe MMR would be willing to ship overseas?
it's still going to cost money for crating,freight forwarder etc.
Thank you all for help
The problem is that my vehicle does not have an engine
The previous engine had an electrolyte problem or else I was going to build it
I found marauder engine in Saudi Arabia imported from America but I do not know if it was clean or not
Price with installation is approximately 1280$
1 month warranty
But the engine is not known how many miles
So I hesitated
There is an alternative solution but I do not know whether it is compatible or not
Search Engine Mustang Cobra 2003 - 2004
Maybe I find a clean engine but I do not know if it will be installed in my vehicle or not
Finally, thank you all for help
Those pics are NOT of a Marauder engine. It looks like a 2V out of a Crown Vic/Grand Marquis. A Cobra engine will fit, but the frame will need to be notched to clear the alternator, or go with the Eaton swap brackets. You will also need a custom tune.
-Mike
#6018 of 11,052
Trilogy #196 - Self-installed
Stuff done to it. See here.
you will need a big checkbook to get all the marauder specific parts needed. those pics are not a marauder motor. other engines can be used but marauder specific parts for the engine will be needed to be swapped. That will be difficult based on where you are.
I am in Saudi Arabia
Marauder engines are rare because the car was not exported mainly to the Middle East
But I think I'll find engines Mustang Cobra 2003-2004
But will you agree with the Marauder without modification or additions?
that is not a marauder engine, marauder engines have twice as wide heads, double overhead cams, DOHC for short, that motor is a SOHC,single overhead cam . about 80 less hp and your computer wont run it. shop owner is wrong
Pictures that you posted are of a 2 valve CV/Grand Marquis SOHC engine.
