Results 1 to 15 of 26
Thread: SPC Camber bolt installation
    Aug 2010
    Gadsden, Al
    Question SPC Camber bolt installation
    Im finally going to drop off my car tomorrow morning to have the SPC Camber bolts installed and aligned to carfixer specs. Can someone point me in the right direction of the camber bolt instructions? It seems like I remember something about some grinding needed during install. Thanks in advance.
    Really looking for a DIY with pics so I can give it to my front end shop to make sure he installs them correctly.
    Jun 2007
    Whitehall, PA
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    May 2011
    Schenectady, NY
    It's pretty straight forward, I did it with a dremel on one side then that died. Then used a drill and a step bit and a hand file. Would have loved a die grinder though.
    300A Black
    THE INSTRUCTIONS ARE IN THE INSTRUCTIONS THAT CAME WITH THE BOLTS.
    $5/5 minutes. Too easy!
    Aug 2010
    Gadsden, Al
    Yea, I saw that when I went in my shop yesterday. Goes to show how long I've had this kit just sitting on the shelf. Why are you yelling Zack attack? Lol
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Aug 2010
    Gadsden, Al
    Mine and my buddies schedule conflict and I'm over doing work like this on my back. Using a lift has spoiled me. Shop is only charging me $110 for install and alignment(carfixer specs)
    My bolt kit came with the aluminum removal bit
    Was probably slightly most costly than just the bolts.
    Won it at a MM.net event raffle
    Jun 2008
    Sorry for the thread bump but this sort of applies.
    Lowered car, SPC camber bolts, Carfixer's specs should still be good, right?
    Quote Originally Posted by a_d_a_m View Post
    Yes.
    56789
    Jun 2008
    Thanks a hundred.
    Q: Is Zack selling these bolts? So, help me out here: do I 1) cut the flags off the stock bolts so they can be adjusted, or 2) cut the flags off the stock bolts so that they can be removed and replaced with these?
    The way I read it just cutting off the flags would work. Don't care either way. I think a die grinder will work better than an sir chisel, so was going to go that route.
    Thanks for any info.
    Zack sells head cooling mod fittings when he has them.
    The SPC bolts should not be needed, UNLESS you have a lowered front suspension from custom coils or coilovers or cut stock springs. Removing the alignment flags should allow enough adjustment for stock height Marauders.
  1. Camber Bolt Install Instructions Power Point Slide.
    By Fly007 in forum Steering, Suspension & Brakes
    Last Post: 09-28-2015, 04:45 PM
  2. So I had a camber bolt back out...
    By CBT in forum Community Discussion
    Last Post: 05-15-2012, 08:36 PM
  3. SPC camber bolts
    By Comin' in Hot in forum Steering, Suspension & Brakes
    Last Post: 09-24-2011, 04:50 PM
  4. New MM Camber Bolts!
    By BizTerp in forum Steering, Suspension & Brakes
    Last Post: 07-21-2011, 04:30 PM
  5. Camber Tires
    By SideshowBob in forum Tires & Wheels
    Last Post: 07-07-2010, 04:29 PM
