Results 1 to 15 of 15
Thread: alternator? battery? help!
    Jul 2015
    waco texas
    Couple of weeks ago car unexpectedly stumbled and died twice on the way home after running errands. Since then car has been driving good with a few stumbles and one shutoff. Car is a weekend and every other day driver. One FLAPS says battery checks good so alternator could be going bad. Another FLAPS says battery & alternator checks good.
    1. Volt gauge goes from 12.5 to 10.5 with combo use of window/full blast use.
    2. Its upper 80s to 90s temp here. Very dry heat
    3. No check engine warning light.
    4. No recent auto work performed. Mileage is 162,496.
    Help help help help would greatly be appreciated. Thanks
    Jan 2015
    Mishawaka, In
    You voltage is to low coming from alternator, generally it's putting out 13.5 to 14.3. Possibly the voltage regulator inside the alternator is bad.
    Oct 2002
    Orlando, FL
    Usually if the alternator is going bad, your battery light should illuminate in the dash indicating that there is a problem with the charging system.
    I'm assuming it turns on as a bulb test before the engine starts, correct? I.e. when you can hear the fuel pump energizing.
    How old is your current battery? If it's 5 years or more, you might want to replace it just because.
    Finally with the stumble or cut-off, are you on your original IAC?
    Hope this helps.
    rkk
    2003 Marauder 300A (Black)
    Born 5/24/2002
    Drove Home 6/26/2002
    Current mileage: 109,907
    Sequence number 569 of 7,839 / 11,052 total
    Joined the 100K club on 5/29/2019
    Mods:
    McGard wheel locks
    Helmholtz Resonator Delete
    Lower Grille Mod
    LCM updated 07/26/2017
    Feb 2015
    South Florida
    I would go ahead and change the alternator and the battery. In the long run you don't have to worry WHAT IF? And you won't be when the MM leaves you stranded. Good luck, oh check the cables might just be loose. One more thing go with Motorcraft 750-850 for the battery.
    Righteous Indignation
    03 300A
    4055 of 7838
    4054 of 7093 in Black.
    Born 8/23/02
    Adopted in 1/15
    SOLD
    Just replace it all! LOL
    Or...
    1 Check condition of cables and make sure there're tight.
    2 Take the battery to a batteries plus for a load test. (Assuming you don't have the tools)
    3 Replace alternator and go buy a nice steak dinner with your savings..
    Jan 2015
    Mishawaka, In
    Or...
    +1 for Bob
    Take it to a FLAPS. They will test it and tell you what the problem is.
    Or...
    For this ^^^ Bob wins the internet for a month.......
    Trilogy # 192 / T.S. 0012
    Jan 2015
    Mishawaka, In
    FLAPS? I don't think she's gonna help but ok
    Quote Originally Posted by mm svt View Post
    FLAPS = Ford-Lincoln Auto Parts Store
    FLAPS = Favorite Local Auto Parts Store
    Yeah, that'll work too !!
    Sep 2005
    APPLE VALLEY,CA
    My alternator did the same thing. It died.
    The Motorcraft replacement did the same thing and died. within 4 months.
    Ford replaced it under warranty for free.
    It's the alternator.
    These rebuilt units (the replacement) are a piece of crap.
    I remember Zack suggesting to get it rebuilt.
    If you have the time, get your alternator rebuilt.
    Jan 2015
    Mishawaka, In
    Alternators that are rebuilt are done so south of the boarder. Take your OEM to a local rebuild shop for quality parts.
    Jul 2015
    waco texas
    Thanks for the response guys. To my knowledge the alternator has never been replaced. Battery is less than 2 yrs old. I went to my local ford dealership to order the $250 alternator. They said those alternators are scarce and they would be "last of the mohicans".
  1. Eaton Swap Battery Cables & Alternator Wiring
    By 8UWITH6 in forum Power Adders
    Last Post: 11-20-2013, 02:13 PM
  2. Battery or alternator or tune?
    By gdsqdcr in forum Shop Talk
    Last Post: 12-16-2011, 03:46 PM
  3. Replies: 50
    Last Post: 10-28-2011, 01:13 PM
  4. New Battery and Alternator - Battery Light Still On
    Last Post: 06-21-2010, 10:07 AM
  5. Battery or alternator
    By 10741 in forum Shop Talk
    Last Post: 06-06-2007, 09:23 AM
