Results 1 to 11 of 11
Thread: Marauder Adventures 2.0
    Sep 2006
    Louisville, KY
    So I've been back in the Marauder game since Feb this year after I sold (like a dumbass) my old Trilogy car in 2011. I bought this car from Ourobos in Bowling Green before his move.
    It had already been Eaton swapped and tuned buy some local guys. I was enjoying the car very much until a guy decided to back into me at a red light one morning resulting in this:
    After Jerry hooked me up with a front bumper and grille I started the body work.
    And the painter thought I needed a different color of primer to help with blocking
    03 Marauder- 300B, non heated seats, T/C, no CD changer
    03 Marauder- 300A, Eaton Swapped, SOLD
    03 Marauder- 300A, 5544 of 7839 in 03, Trilogy #24, SOLD
    04 Marauder- 300B, SB with LF interior, 208k miles and still ticking SOLD
    Sep 2006
    Louisville, KY
    After lots of sanding, filler, blocking and more primer it got a coat of base
    Then done
    The car turned 200k on my way home from work one day
    Then I started working on the grille
    The roof was a sore spot on this car, it had chips and surface rust so I needed to address it soon. I started sanding and found it had been painted once before and there was rusty chips under the top coat of paint
    This was after 1.5 hours and 10 sheets of 120 grit discs.
    May 2009
    Moreau Island
    Why not blast the paint?
    Sep 2006
    Louisville, KY
    I work at a body shop and the materials don't cost me anything. Soda blasting is expensive in our area as we only have a few folks who do it.
    Sep 2006
    Clermont Florida
    Looking good Drew !!
    Cochran, Georgia
    Looks like you are doing a good job. Just a quick question are they putting in the paint additive for the bumper paint since it flexes so much? I had one painted and they did not use it so it is now cracking.
    2004 SB Marauder, SOLD
    Winnipeg,Mb.
    Looking good! I too am finally going to address my blistering roof this year. I've got an appointment to have an estimate done tomorrow.
    -Mike
    #6018 of 11,052
    Trilogy #196 - Self-installed
    Stuff done to it. See here.
    Aug 2007
    las vegas
    Quote Originally Posted by Gryphonzus View Post
    Most good quality clears now a days are some what flexible, (when mixing with the proper ratio). Also, nearly all flex additive goes away over time. BASF, or R&M, made a flex agent that actually cross linked at a molecular level and did not go away over time. Mill thickness has something to do with it also, piling on the clear is not a good idea on bumpers.
    Sep 2006
    Louisville, KY
    Yes, we will use a little bit of flex additive in the base. The front bumper was cracked all the way to the urethane and so is the rear bumper. The only way to fix this is to sand / grind out the cracks and apply a light coat of flexible filler then prime and block.
    Quote Originally Posted by 03blackvegas View Post
    This is correct. We are using a production clear by Sikkens (which I'm not a fan of the way it sprays or looks) but we are going to add an extra two coats on the body for buffing but nothing excessive.
    Sep 2006
    Louisville, KY
    I was reading through some MM for sale ads one day and ran across a guy who listed his mods and one caught my eye. 2015 Mustang GT LED Fog Light mod. I tried to contact him and never got a response so I started looking at the lights on ebay to get an idea if they would work. I ordered a pair for around $70 for the aftermarket version.
    I had already been under the front of the car and noticed I had a broken fog light bracket so I ordered a new pair from Rock Auto.
    I wanted to see how close the tabs lined up to the holes in the MM bracket
    So I need to fab some brackets to hold it in place. The easiest thing I've used over the years is plumbing straps. They bend easily and are very cheap in a roll.
    So after trimming and raiding the screw drawers I figured out a way to mount them
    I will need to modify the wiring to adapt to the new light, but from just hooking it up to a battery I can tell they are much brighter and have a "flatter" light pattern.
    Feb 2005
    DC MD Area
    Very interesting. I may do this.
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
  1. Juice's photography adventures
    By Juice in forum Photography Forum
    Last Post: 09-10-2012, 02:23 PM
  2. Spam Adventures
    By SHERIFF in forum The Lounge
    Last Post: 01-05-2004, 08:27 PM
  3. Adventures In A Grand Marquis!
    Last Post: 12-06-2003, 06:39 PM
