So I had my car aligned using car fixer specs and the car tracks straight but steering wheel is slightly off center. I did make sure tire pressure is correct. What is required to fix this? Thanks
2003 300A
black
XCAL2 (DENNIS REINHARDT)
blue inserts
GODSHEAD oil cap (COLEX)
GODSHEAD badging(CARMOTORSPORTS)
flowmaster super 40s
silverstars
BADGELESS GRILLE(2ND OWNER)
DRILLED/SLOTTED ROTORS
NAPA CERAMIC PADS
PROGUARD(DENNIS REINHARDT)
ADDCO FRONT AND REAR SWAYS(DENNIS REINHARDT)
MACH 1 CHIN SPOILER(INNNOVATIVE INTERCEPTORS)
2003 300A
black
blue inserts
silverstars
NAPA CERAMIC PADS
Usually when you change the ball joints and pit arms on the front suspension the wheel gets out of wack and then the alignment rectifies it.
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15
SOLD
I took mine back 3 times with 3 different alignment techs until they got it right. The first run was on a machine that wasn't calibrated, 2nd tech had issues with the front being lowered. Replaced springs and had a 3rd tech (who knew what he was doing) got it right.
Was going to bring this up whenever we get together here in Atlanta again. Did not know this was a condition. Story: Went to Mo's Speedshop to have my Baer Rotors turned. They discovered my rightside Swaybar Link was broken. The "Young Lady" put some miles on my '03 for a while and of course didn't report "every" pothole encountered. I knew of a minor curb incident on that side. Jeff at Mo's explained the original Ford Swaybar Links are weak and break when overstressed. They replaced both with MOOG products supposed to be more durable and come with grease fittings. THE RESULT: For the longest, after another alignment, I thought the car just drove that way, wasn't Bad, and I'd never get it as good as it was. Well, with this replacement, Phenomenally driving straight with ease !
2003 300A
black
blue inserts
silverstars
NAPA CERAMIC PADS
EXACTLY--If wheel alignment was "supposedly" done to specs and road and wheel is straight and the car steers left to where correction is needed or end up in other lane, then ^^^ what he says ^^^^EXACTLY.
What said above again--job not done correctly--period--regardless of what was used...
.....and apparently like several, see below---this one didn't know either-- take it back!
Think we have rested our case here ---you know what to do--
12.45 at 109.6 MPH
1.92 Sec .- 60 '
Alt .SSHS 9 --11/7/09
'06 CV P71 Street Pkg
Interior Marauder Floor Shift
All New Parts
In Memoriam....11-14-13
The tie rod ends need to be adjusted. If you adjust both sides equally it will move the steering wheel without messing up the alignment.
Toe... If toe isn't equal between both sides, WITH the steering wheel straight, when you start driving, the wheels automatically center, which then causes the steering wheel not to be centered. So basically like everyone said, guy didn't do it right.
Edit: just saw ford nuts reply, my bad. What he said
Your wheel alignment and repairs are only as good as the tech who does them...
Pete...
DOB 10/31/2003
DOP 1/2/2004
DOB 12/11/2018
DOP 6/19/2019
Sorry, know this is an older thread, but this seems to be the place for it. My experience: bought a new set of Nittos 23k miles ago, printed out Carfixers specs, and specifically asked the alignment guy to use them.
The rears will make it to the 30k easy, and the right front looks ok on the inside, but the left front inside is just gone. At least 1/4" or 3/8" eaten down to the steel for 1/2" on the inside.
I don't know anything about alignment. So, did they blow me off and do the oem alignment?
BUT, the wear indicators are also flush with the tread, so I'm just going to ask the dealer to adjust the tire based on the wear. They're at 80% in the front and about done, so I'll see about that, but thanks for any info on the alignment issues.
My guess is that they generally followed his specs, but maybe I hit a major pothole and tweaked it on that side only? Can't figure out why just one front inside would be so badly worn compared to the other.
Tnx.
