Results 1 to 9 of 9
Thread: High Volume Water Pump
    So, I'm just checking my research out. I'm getting ready to replace the timing chains/guides/tensioners/etc. While I'm at it, I'm going to replace the water pump.
    Are these two the correct choice? Short style, correct?
    Edelbrock 8803
    EMP Stweart STE50046S
    Pat
    Speed costs money. How fast do you want to spend?
    03 300A
    #3350 8/2/2002
    23-ish T-Bucket
    Washington State
    Why not just use one from Ford?
    Feb 2006
    Rosemount, MN
    I have the EMP Stewart and if I recall I was impressed with it's quality. The impeller looked much more efficient that the OEM Ford.
    Feb 2006
    Rosemount, MN
    Jun 2007
    Whitehall, PA
    I got a Stewart EMP when I changed mine at 179k. It's quality part.
    2003 DBP/LF - # 36 (Sold)
    2003 DBP/LF - # 205 (Sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox
    Oct 2003
    Beaufort, SC
    The Ford part works just fine.....I have the EMP Stewart one and have seen no real advantage over the OEM pump!!
    Spent your money elsewhere!!
    If I recall correctly there was a higher flow OEM Ford water pump. Maybe it came on Navigators? I also have an aftermarket pump, from Evans. I didn't see any real benefit.
    Thanks!
    I work in the parts biz, so I get it at cost.
    And I might as well get this out of the way, because I always get asked: Sorry, I can't get anyone else a discount. It could cost me my job!
    I plan on gradually upping the power of this motor, and taking it down the drag strip quite a bit. So I really want to up the cooling capacity.
    Pat
    03 300A
    #3350 8/2/2002
    23-ish T-Bucket
    May 2013
    Saudi Arabia
    Same here Stewart EMP FTW
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
  1. Replies: 11
    Last Post: 03-20-2015, 07:12 AM
  2. EMP/Stewart high performance water pump install
    By Blackened300a in forum Shop Talk
    Last Post: 09-19-2011, 12:51 PM
  3. Electric Water Pump or Stewart high eff????
    By lincolnpimp in forum Shop Talk
    Last Post: 11-02-2008, 11:09 AM
  4. High flow water pump.
    By collins8 in forum Shop Talk
    Last Post: 07-18-2008, 12:43 PM
  5. High flow water pump
    By Pops in forum Shop Talk
    Last Post: 03-03-2008, 08:40 PM
