Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: First trip with the marauder
    Jan 2016
    South NJ
    Stock Marauder, tune from Marty, k&n intake setup, and a 2.5 inch x pipe in place of the stock tiny one, all factory cats and mufflers etc. Had a trunk full of tools, a jack and the spare. Just as I do every day. I don't play the weight game.
    14.73 @ 96.09 was the best run of the night once I pulled 2 degrees of wot timing for some odd reason...honestly I guessed 14.50s before I ran, but doesn't it always work that way?
    I was trying to avoid any gear in this car but boy does it need it. I shifted into third right before the traps. Awful. I'm, just going to put 4.10s in it. Especially since I bought the car with 255 tires on the rear already.
    Will update when I go back with the gears.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    14.33 @ 96.82 with OLD engine
    6R80 swap in progress
    1968 Chevelle
    NA/Pump Gas 10.4 @ 128 mph
    416/4L85E LSA Supercharged build underway
    Blog Entries
    2
    Nice run!
    can you please post all your #s and approx Temp/Hum?
    Thank you.
    Aug 2014
    Fort Benning, GA
    I have a 96 Cobra and it runs 13.9... Not bad..
    May 2009
    Moreau Island
    Where did you run?
    Jan 2016
    South NJ
    Atco. DA was 84 ft where I ran:
    2.218
    6.303
    9.605 @ 75.38
    12.382
    14.74 @ 95.81
    (Edited because last posted time was the wrong slip)
    . Best run was -120ft so the couple degrees timing seems to have done very little.
    2.247
    6.330
    9.595 @ 75.65
    12.388
    14.739 @ 96.09
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Jan 2016
    South NJ
    Had a couple people come up to me and ask about the car. I kept telling them it's just stock and they didn't seem to believe me. I just laughed because it's really not special. Looked good doing it tho.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Jan 2016
    South NJ
    It was a good night tho. Helped my buddy with his first time at the track, and ran against my best friend with his "new" stock 1978 corvette. When everyone runs and no one breaks, it's a good night.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Nice run!
    Lost my 1/4 mile track, city bought the land
    If you barely click the second lights, you might get a better 60' time. Try it
    Do your rolling burnout up away from the burnout box, this way you don't collect other rubber pieces when you pull up to the light
    Not a rolling burnout past the lights, just make sure your way past others burnouts
    Let us know your next trip, sounds fun
    Jan 2016
    South NJ
    Nice run!
    Ur talking about shallow staging. Yep I do it on a regular basis. Not my first rodeo.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Aug 2010
    Southern NJ - Exit 4
    Quote Originally Posted by 376shovel View Post
    2.218
    6.303
    9.605 @ 75.38
    12.382
    14.74 @ 95.81
    2.247
    6.330
    9.595 @ 75.65
    12.388
    14.739 @ 96.09
    That's a VIOLATION!!
    All Marauder racing at Akko (Atco) must be announced prior to the race.
    Jan 2016
    South NJ
    Quote Originally Posted by WhatsUpDOHC View Post
    ? Because of the DA? It was good but not -1500 good.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Jan 2016
    South NJ
    The way my exhaust is set up. I could just buy a set of headers and fit them right to my existing system without having to buy anything else. The car definetly needs gear. So now I'm at a decision point. $1300 for some gear and headers, or what $2800+ for an Eaton swap?
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
    Hiram, Georgia
    If you can do an Eaton swap fir $2,800 I will take three please.
    Aug 2010
    Violation because I didn't know about it (So that I could be there to see the runs).
    Jan 2016
    South NJ
    Sorry brother didn't think about it. I will be going again later this year I'm sure.
    Marty I priced based on the parts available on the forum, and eBay. Also accounting for selling my k&n intake, the upper/lower intake, throttle body, injectors etc for a couple hundred bucks to offset. What big costs am I missing?
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  1. Marauder served me well on my trip...
    By CKMustangCobra in forum Community Discussion
    Last Post: 01-27-2009, 07:59 AM
  2. Marauder's First trip to the track
    By Eric91Z in forum Community Discussion
    Last Post: 10-17-2005, 08:50 AM
  3. MARAUDER SIGHTINGS: My trip to MA today
    By Dan in forum Community Discussion
    Last Post: 10-03-2004, 03:29 PM
