Results 1 to 4 of 4
Thread: I'm back with Purple Panther
    Nov 2010
    schenectady
    Last oct. i broke the crankshaft at the track and damaged the heads again.The moter was repaired and the heads finally came back from california after 7 months.I also added a new sheet metal intake from MMR.The car was on the dyno tuesday and made 890 RWHP.
    Before the race heads and intake 756 RWHP
    with race heads 803 RWHP
    with race heads and new intake 890 RWHP A total increase of 134 RWHP
    We will see what it does at the track next week.
    With the black car i sold the 2400 HP motor put a new 582 CI, BBC with Brodix SR 20 heads and left it N.A. It put out 1100 crank HP @ 7100 rpm and 881 torque @ 5200.It runs 9.04 @ 148 with no problems after 45 runs.
    I will post pictures when i can figure out how i did it l.y.
    Nov 2010
    schenectady
    I'm back with pics
    I think we've solved it
    Attached Files Attached Files
    May 2011
    Schenectady, NY
    Good to hear from ya joe. Sounds like you have been busy!
    300A Black
    Blog Entries
    2
    Make some Smoke!
  1. purple panther
    By Triple Threat in forum Drag Racing Round-up
    Last Post: 10-05-2018, 12:58 PM
  2. Purple Panther goes even faster
    Last Post: 09-18-2017, 04:18 PM
  3. Purple Panther new best times
    Last Post: 08-28-2017, 05:36 PM
  4. Purple Panther 803 RWHP
    Last Post: 05-28-2017, 07:11 PM
  5. New motor for PURPLE PANTHER
    Last Post: 10-17-2012, 09:08 AM
