Results 1 to 15 of 27
Thread: New Products: Custom 4V Coil covers
    These new custom Coil Covers from Fore Precision are awesome.
    We are a stocking dealer and have many sets ready to go.
    Here's what they have:
    <!-- InstanceEndEditable --><!-- InstanceBeginEditable name="EditReg_main" -->Ultra Low Profile Coil Covers Fits: Ford modular four valve V-8 engines
    These coil covers are machined from 6061-T6, andodized black, then chamfered and engraved to reveal the shiny aluminum below. The contrast is astounding.
    The Ultra Low Profile Coil covers are 3.5mm shorter than the stock covers while allowing the same clearance under the covers. These coil covers bolt on with included 316 stainless steel hex head bolts without any modification. The use of the OEM coil cover gasket is maintained making these a hassle free bolt on that retains complete factory reliability.
    Tall Coil Covers
    Fits: Ford modular four valve V-8 engines with stock or GMS ignition coils
    The Tall Coil covers are roughly 1/4" taller than the stock covers while allowing connector clearance for aftermarket GMS coil kits. These coil covers bolt on with included 316 stainless steel hex head bolts without any modification. The use of the OEM coil cover gasket is maintained making these a hassle free bolt on that retains complete factory reliability, unlike the spacer that deletes the OEM gasket, allowing debris to accumulate in the spark plug wells.
    <NOSCRIPT></NOSCRIPT><SCRIPT language=JavaScript><!--var SymRealOnLoad;var SymRealOnUnload;function SymOnUnload(){ window.open = SymWinOpen; if(SymRealOnUnload != null) SymRealOnUnload();}function SymOnLoad(){ if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymRealOnUnload = window.onunload; window.onunload = SymOnUnload;}SymRealOnLoad = window.onload;window.onload = SymOnLoad;//--></SCRIPT>
    <NOSCRIPT></NOSCRIPT>Here's what we can do.
    They come blank or with engraving. Normally the engraving is on the driver side, but if there is interest I can get a batch done on the passanger side for the Marauder. We can also do some engraving bare aluminum coil covers, media blasting, then clear anodizing, for contrasting colors to your black valve covers.
    So they run:
    $130 blank (Black or clear/silver)
    $145 with engraving
    Blank (black) sets are in stock and shipping now, if you would like engraving please let me know what you would like most.
    I'm thinking "4V 281 Marauder" or "4V 281 SUPERCHARGED" for you supercharged guys. The engraving will take some extra time, but too long.
    We are also doing "JLT Performance" engraving as well. I like these one
    If I can confirm at least 5 sets with one or the other or both I'll get them started.
    Thanks for looking and give me your thoughts,
    Jay
    2013 Mustang GT 5.0
    Gotta Have It Green
    Blown and bad 725 RWHP
    JLT Performance Marauder Intakes
    JLT Crown Vic Intakes SHIPPING only $129! NO tuning needed!
    Marauder parts:
    JLT RAI intakes
    Drive shaft loops
    SCT X-3
    Metco control arms
    Call or E-mail me for your needs!
    Jay Tucker @ 757 335 1940 or Jay@JLTtruecoldair.com
    Oct 2003
    Afhaggisland
    Looking good...
    Can we get them with personalized engraving?
    Saorsa gu Brath
    (Freedon Forever)
    Si vis pacem para bellum
    Μολὼν λαβέ
    (Come and take them)
    Stann saam of sterf allen
    (Stand together or die alone)
    Audentis Fortuna Iuvat
    (Fortune Favors the Brave)
    "THE BLACK BOMBER"
    We can do personal engraving, it will just take a little longer.
    No problem.
    Jay
    2013 Mustang GT 5.0
    Gotta Have It Green
    Marauder parts:
    JLT RAI intakes
    Drive shaft loops
    SCT X-3
    Metco control arms
    Jan 2006
    Central Ohio
    Quote Originally Posted by Tucker View Post
    Hmmmmm..... KillJoy Covers.....
    KillJoy
    Oct 2003
    Afhaggisland
    COOL....
    Does the andodized black match the black of the valve covers in the '03?
    Saorsa gu Brath
    (Freedon Forever)
    Μολὼν λαβέ
    "THE BLACK BOMBER"
    May 2005
    Amissville VA
    Those look great!
    The tall covers are just what some will need who want to get this larger GMS coils too.
    Trilogy #112 (self installed)
    12.99@106.2mph (for now)
    Apr 2005
    The Pitt, PA
    Anodized will be smooth. Our black is a spray-on finish. They'll match by color but not by texture.
    2013 Ford Taurus SHO
    #1649
    boi
    Everett, WA
    I'm in for an engraved TALL set in black. Both sides to be engraved thusly:
    4V 4.6L
    SUPERCHARGED
    2003 300A Black Mercury Marauder 4334 of 7839
    Trilogy #150 installed by Carfixer & Tallboy 4/21/2007
    (brute's garage)
    For engraving on both sides it will run $15 extra.
    I did both sides on mine.
    Most are only one side due to the intake covering most of the one side, but you can still see it.
    Thanks
    Jay
    2013 Mustang GT 5.0
    Gotta Have It Green
    Marauder parts:
    JLT RAI intakes
    Drive shaft loops
    SCT X-3
    Metco control arms
    Dec 2006
    Eagle Pass, TX
    Count me in for a black passenger side engraving covers.
    Without Change, There can be no Victory.
    Apr 2005
    Queens NY
    Any chance of getting a God's head on the cover?
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    If someone can send me a 'dxf" or "eps" file I'll see what I can do
    jay@jlttruecoldair.com
    2013 Mustang GT 5.0
    Gotta Have It Green
    Marauder parts:
    JLT RAI intakes
    Drive shaft loops
    SCT X-3
    Metco control arms
    Nov 2003
    The Land of Aquila
    Any more word on these? Do you have five orders yet?
    Widowmaker
    May 2004
    A COOL place!
    Oh ya S55 MARAUDER WITH GODS head!!!
    # 2352 Lidio Built my Hot Rod... 2011 S55-001
    I should have a set of 4V281 SUPERCHARGED today. I'll take some pics and post them.
    I need to keep the engraving to a minimum on my stocking parts as the more we have the more I need to stock. I like to stock parts in the amounts of 20-30, so I will keep it to blank and 1 or 2 others.
    Any custom order can be done for sure, but will take a week or so to be done. Not a huge time delay by any means.
    As for the Gods head, I need a file to do it. If anyone has it or knows where to get it let me know,
    Thanks
    Jay
    2013 Mustang GT 5.0
    Gotta Have It Green
    Marauder parts:
    JLT RAI intakes
    Drive shaft loops
    SCT X-3
    Metco control arms
  1. Coil covers and buttons
    By SID210SA in forum Colex Inc.
    Last Post: 02-20-2007, 07:50 PM
  2. Custom Coil Covers
    By JFB in forum Community Discussion
    Last Post: 03-15-2005, 06:23 AM
  3. Custom 'COIL COVERS'
    Last Post: 03-14-2005, 09:22 PM
  4. Custom Billet Coil Covers -
    Last Post: 03-11-2005, 10:11 AM
  5. Heros and Coil Covers
    By rumble in forum Community Discussion
    Last Post: 11-15-2004, 09:13 PM
