Results 1 to 15 of 26
Thread: Is this 100% the blower motor?
    Aug 2013
    Woodridge, IL.
    So, 91 degrees today, I drove 150 miles up to Madison with the AC on, then made it about 75 miles back home with the AC still going when it just stopped blowing. Got no AC except a faint breeze of it in "NORM AC" setting while the car was in motion on the highway, got nothing as we slowed or stopped. Got home, check three fuses that could be EATC or blower related inside the cabin, they all looked good, then swapped the 40A blower motor fuse (301) with another one in the same fuse box under the hood, that didn't work. Then even gave the blower a few good taps which also got me nowhere. Also, did the EATC self test twice, nothing but 8's. Did I miss any possibilities? Any other tests or things I could check to be positive. Or have I done it all and it's time to invest in a new blower motor? (Ps, if it's pertinent information, I've never replaced the blower motor before, and the car currently has about 175k miles on her, 75k I put on.)
    Feb 2012
    harrison twp,mi
    Quote Originally Posted by tylerdurden2816 View Post
    Try tapping the blower control module "bcm" on the fire wall just to the right of the heater core if your facing the firewall.
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    What he said ^^^
    Also set the fan control to high and check the voltage at the blower motor...should be a full 12V. If so, then the blower motor is bad; if not, then prolly the BCM or (less likely) the EATC itself.
    +3 on the BCM.
    Aug 2013
    Woodridge, IL.
    This is the guy I need to smack around a bit?
    Yes.
    give it rap with a screwdriver handle, if the blower works, then it means the BCM is bad (solder joint over time goes bad.cracks) there is a write up on here with pics to show how to change it.
    Nov 2009
    Ontario Canada
    Last time I changed the blower motor resistor I managed to get one for about 30$, sounds like it's the culprit in your case as well as others have suggested.
    1987 GN running 10's. 2003 MM Blue Sold and dearly missed!
    2003 Black 300B
    Procharger P1sc with air to air intercooler
    3,000 PI converter
    4.10 Eaton posi 31 spline carrier
    Moser 31 spline axles
    Koos headers, with custom stainless exhaust, Megs tips
    Carbon fiber drive shaft
    Metco control arms
    Every autometer procomp gauge in the catalogue
    It's 32.00 at rock auto AND you can use our 5% discount
    Please give your engine bay a good cleaning
    Quote Originally Posted by JimP View Post
    FYI, cars with EATC don't have a resistor, it's a PWM controller. Cars with manual HVAC have a conventional resistor pack.
    I can fix it for you.
    Aug 2013
    Woodridge, IL.
    Ok, well it's not the blower motor, however, rapping on the BMC did not move the blower at all. So is it still the BCM then? (I jumped the blower to the battery and it started right up lol)
    May 2011
    Schenectady, NY
    You need to smack yourself around a bit and clean that damn engine bay
    300A Black
    Aug 2013
    Woodridge, IL.
    Damn, u guys are savage...
    I still think the BCM is suspect.
    It could be the EATC.
    http://mercurymarauder.net/forums/sh...ad.php?t=99619
  1. just the blower motor right?
    By Ravage17 in forum Shop Talk
    Last Post: 07-30-2011, 06:55 PM
  2. Fan Blower Motor
    By Tamthemaam in forum Community Discussion
    Last Post: 04-23-2009, 12:12 PM
  3. Ac/ heat blower motor out!!
    By silvermm254 in forum Shop Talk
    Last Post: 01-25-2009, 06:38 AM
  4. need to test my a/c blower motor
    By baltimoremm in forum Shop Talk
    Last Post: 11-03-2008, 08:44 AM
  5. Motor and blower for sale
    By Tom Doan in forum Community Discussion
    Last Post: 06-20-2005, 12:54 PM
