Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: WATTS link installed
    May 2003
    South Fl
    Ok, so I dropped off my car to get a oil change done and a once over befor I drive up for MVIII. But while its there RoyLPita offered to install my WATTS link, he even lent me the use of his CV to get to work. Great service from a great friend, now if it wasnt raining I could comment on the feel of the WATTS link. Thank you again Brian.
    South Florida
    Blog Entries
    1
    That was nice of RoyLPita (aka) Brian to lend you his car. I hope you like your watt's link. Have a safe trip.
    I'd be interested in hearing what you think of your new watts link setup when you get the chance to test it out in nice weather. Was this the Metco kit?
    2003 Mercury Marauder
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    May 2003
    South Fl
    Yes, this was the Metco kit, I had already installed the Addco front and rear sway bars aswell as the Metco control arms.
    Off-Shore America
    I'm interested in your results too, thanks.
    Feb 2005
    Clinton, MD
    What is a WATTS link? What does it do?
    Welcome to the DARKSIDE...
    2003 Black Mercury Marauder
    Black and Chrome RPM 505 wheels staggered 18x8 and 18x9, Custom tune by ELD Performance, JLT cold air intake, FRPP 4:10 gears, PI 3000 Stall Torque converter, PHP intake spacer, Stainless Works Complete Exhaust, Eibach Pro Springs, Steeda underdrive pulleys, Custom Painted Black factory spoiler, 15% Tint front and rear , Kenwood Excelon 6x8 Front and 6x9 rear Speakers, Pioneer 600w 4 channel amp, Zack and Mack Control arms, Addco Front and Rear Sway bars
    Best run: 13.75 @ 99.6 sec on 4 May 07
    Quote Originally Posted by Big House
    It's part of the rear suspension. A necessary upgrade to the factory suspension to eliminate body roll in addition to the rear & rear sway bars and upper & lower rear control arms. You can throw in QA1 coil-over front shocks for a complete suspension upgrade.
    Feb 2005
    Clinton, MD
    Thanks. I will stick with my Eibachs for a while. The coil overs I can wait on. Looking to do the sway bars though. But the way his car handles stock, I am almost afraid to do anything else to the suspension.
    San Diego
    Very happy with mine
    Had my Metco Watts Link installed at Collins L-M in Indy during MV2. It was a little tricky but the Master Tech, Danny Boone, did a super job.
    It was obvious right away that I had less movement in the cabin from side to side.
    4th Horseman and my brother were both there when I had it installed, and it took slightly longer than we thought.
    Cost us our B-B-Q dinner at Kenny Brown's because the membership ate it all before we got there. But it was well worth it just to have that Watts Link installed.
    The Metco folks are great also, they brought my Watts Link to Indy from North Carolina. Had it waiting for me in the box with my name on it at the Metco tent.
    Let us know what you think of it Soul! Regards, -kjs-
    My car has the front/rear swaybars, metco control arms, and watts link, anyone considering these mods, at MV3 is welcome to go for a drive. You wont be disappointed. The ride is firmer, but still very very comfortable, it handles like its on rails.
    May 2004
    Bradenton, Florida
    It's the three dimensional geometrical equivalent of the diagonal brace you see that builders put on walls before they put paneling on them. Without a link of some kind to locate the axle and prevent side to side motion the wheels would come out from under the wheel wells on turns. It doesn't do anything to prevent body tilting or roll. That's what sway bars are for.
    Ever see an old '80s model CV or GM going over small bumps and notice how the rear end started to wiggle side to side? That's because it used a cheaper single bar that went from a bushing at one side of the rear axle and traversed about three and a half feet across the car to attach to a bushing at the body. This single bar was putting the side to side motion into the car because of the geometry, the planar location between axle and body changed as the axle traveled up and down. Imagine the lower control arms and their four bushings making the four corners of a rectangle. With the old single bar the short legs of this rectangle moved a little bit from side to side because the bar had to be at a slight diagonal sometime during the axles travel up and down. Up and it pushed the axle a little over to the right, down and it pulled the axle to the left. This is a bad thing two ways, wiggling the passengers and worse, shaking the axle side to side during turns that had bumps, compromising traction.
    A Watts Link is two bars that each come from the body and connect to a bell crank located on the differential housing which cancels out the side to side deflections of each arm of the link assembly, giving a pefectly perpendicular up and down motion of the rear axle and wheels. It's the hot setup for drivers with solid rear axles that wanna push hard through those curves. Our car has this as a stock setup, but the arms are flimsy P's-O-S with mushy rubber bushings. The full Metco treatment is the only way to go!
    SouLRiot be makin smoother curvy skid marks now! Bro', your car will now leap and land sure footed like the true life panther her chassis is named for. Congratulations. It's a very noticeable improvement.
    ditto as well...
    2017 Niro
    Brooklyn N.Y
    ditto as well...
    I have the Metco upper and lower control arms along with the QA 1 coilovers. I also have the rear swaybar from addco. Let me know if I heard wrong but I coould have sworn Dennis said to stay away from the Heavy duty front sway bar because of concerns of weight transfer problems. Guys help me with this go with the front bar or not
    Blog Entries
    2
    I drove an MM with the Metco watts and the back end was real twitchy. The solution was a beefier front sway. I didn't drive it with the beefier front sway but the owner reports it cured the problem.
    I beefier front sway reduces weight transfer to the rear which results in less traction.
    Aug 2005
    JUPITER
    Two questions.
    At what points does the Metco Watts connect? Is it body mounted or differential mounted?
    What is the spring rating on the QA-1 coil-overs? Does the kit replace the whole stock cpoil-over spring and strut? Is the kit spring rate different from stock?
    Thanks!!
  1. Metco Watts Link Installed
    Last Post: 04-24-2005, 08:54 PM
  2. Sway Bar + Control Arms + Watts Link + Tires + Alignment = WOW
    By Agent M79 in forum Community Discussion
    Last Post: 03-07-2005, 10:15 AM
  3. Who wants a Z&M Watts link?
    By Petrograde in forum Shop Talk
    Last Post: 03-14-2004, 08:38 PM
