Results 1 to 15 of 15
Thread: ABS Module
    Mar 2014
    Kailua, Hawaii
    ABS Module
    I believe my ABS Control Modules is failing... I want to replace it.
    Question I have is the part number on my module is 3W33-2C353-F can't find any online and Most units I find online are 3W13-2C353-A and that's for a 03-04 Grand Marquis / Town Car
    Are these interchangeable with an 03 Marauder with traction control?
    They are physically interchangeable, where the difference lies is the marauder version is calibrated for the staggered tires. If your car is a 300A, you should be ok.
    What specifically is the problem with the ABS?
    Sent from my iPhone while doing a big ole' smokey burnout in my wife's Prius.
    Trilogy # 192 / T.S. 0012
    Apr 2016
    New Lenox IL
    PM turboV6bryan,
    He was going to help me out with one but I ended finding up one locally right before he responded to my thread.
    I have one from a 03 with 300a
    No traction control. I'll get the # off it
    Chicago
    Marauder specific, we tried a GM on mine - didn't work. If yours has traction control make sure it is a module from an MM with traction control, took me a bit of searching to find a used one. New ones are out there but expensive.
    Steven
    2004 Marauder Black, loaded
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    476.9 rwhp 385 lbs/tq
    Lidio tune
    2004 Suburban Dark Charcoal
    Mar 2014
    Kailua, Hawaii
    I can't pull ABS codes with my AutoXray EZScan6000...... which is sad. However my Mark VIII had a similar symptom which turned out to be bad solder joints in the solenoid section.
    Symptoms are my ABS Light and Brake light on the dash stays all the time.
    I checked resistance on all wheel sensors and they are in range 1369 ohms on the fronts and 1730 ohms for the rears. All fuses are okay.
    Once in a great while when driving around the ABS & Brake lights will turn off and i'm able to toggle the traction control, but less then a minute later the lights will come back on and I can't toggle traction.
    As for the 300A vs 300B..... I have a Black car with traction control, no indash clock, no sunroof, no heated seats. I have pockets in the front of my seats.
    This is the one I have. No traction control = 300a for 03
    Jun 2012
    Grand Rapids
    As stevengerard stated they are NOT interchangeable at all. Marauder is specific and there are NO replacements available any longer.
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Chris, what about for a 300a without TC?
    Mar 2014
    Kailua, Hawaii
    I have traction control on my Marauder. A non traction control unit wouldn't just bolt up... Right?
    Mar 2014
    Kailua, Hawaii
    So... Being that other ABS modules from different models with traction control such as (Town Car/Grand Marquis/Crown Victoria) won't work as a replacement for the Marauder ABS module.
    Are all modules for Marauders with Traction Control the same?
    Chicago
    Quote Originally Posted by MikeyMikeV8 View Post
    It would bolt right up but my understanding, from research I did and all the work Chris tried to do to circumvent it, the programing doesn't work. A MM with Traction Control needs an ABS module from an MM with TC
    I believe so but I made sure I got an 04 module just to be sure
    Steven
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    Lidio tune
    Find someone parting a 300b 2003. It'll have the same part # and swap right in
    Hope someone here has one
    Quote Originally Posted by stevengerard View Post
    Or just change out the module and pump. And..... There are companies that rebuild these, just an FYI..........
    Chicago
    I found a couple of companies, so yes I know they are out there, but their inability to return a call/email make me suspect of them returning my part.
    Steven
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    Lidio tune
  1. I got air in my ABS module....
    By Motorhead350 in forum Steering, Suspension & Brakes
    Last Post: 03-06-2013, 08:21 PM
  2. Wanted To Buy ABS Module (ECU)
    By PlaneMech in forum Marauder Parts/Misc. Wanted
    Last Post: 01-10-2012, 05:58 AM
  3. ABS Module bad
    By Pat in forum Shop Talk
    Last Post: 09-01-2011, 06:55 PM
  4. Abs module
    By Coupe in forum Marauder Parts/Misc. Wanted
    Last Post: 05-11-2009, 01:04 AM
  5. DRL Module
    By Black Terror in forum Community Discussion
    Last Post: 01-09-2003, 07:56 AM
