The ad makes no sense.
Will you take a check? ****fingers crossed****
Yes, I will accept a cashiers check. You can hand it to Marty when you pick up the parts.
The picture shows a NA lower intake. I know your not mechanically inclined but, that intake won't work with a PD SC.
The ad states Cobra Lower that's been powdercoated.. Which is a totally diffrent intake.
Your welcome!
Anyone looking to buy this needs an aftermarket hood to make it work. The GT500 adapter is a 2 piece unit which means it will be too tall to mount under a stock hood unless you fab a short set of motor mounts. I'm not sure if the Mammoth inlet will clear the wiper cowl but it looks like the fabricator took that in account when he made the TB spacer.
All in all its a variation of the CobraEngineering GT500 swap kit and should make tons of power.
It looks killer! I would like to know why you aren't using it?
Damn..... I NEED that, and my hood will clear it...
Trilogy # 192 / T.S. 0012
"Anyone looking to buy this needs an aftermarket hood to make it work."
You are correct. I grew tired of trying to find a custom car shop that does high quality metal fabrication to build me a custom steel hood. The cost would have been $5000 - 8000.00. No matter, six months of trying yielded zero takers.
"I'm not sure if the Mammoth inlet will clear the wiper cowl but it looks like the fabricator took that in account when he made the TB spacer."
He did and it does.
I had a private offer (not a bid) of $6200. The buyer lives nearby, which is no advantage with the blower and accessories at MO's Speed Shop. He made his offer contingent upon everything working with his 1970 Chevelle SS with an LS2 engine.
I declined his offer and smiled knowing there are others like me out there (low knowledge). I hope he has access to a forum with experts like we have.
