Results 1 to 11 of 11
Thread: Is the LCM Programmable for LED LIGHTS?
    Jun 2018
    Aurora, Colorado
    Cool Is the LCM Programmable for LED LIGHTS?
    I understand that the LCM can be programmed. Since the turn signal and hazard warning flash is controlled by the LCM I would like to know if it can be programmed to accommodate the LEDs. I believe that simply replacing the turn signal bulbs will result in “hyper flash” since one cannot replace just the flasher. Anyone crossed this bridge yet? Have not gotten an answer from FOMOCO yet..
    Jul 2014
    NY
    You may want to reach out to FastBlackMerc, he is an expert with these.
    Jun 2015
    O'Hare IL
    It's not tunnable or reprogramable far as I know.
    In order to fix the hyper flash you need to add a resistor in the wiring before the bulb. It's not complicated many have done it.
    program the LCM, no..you need to add an electronic flasher..
    A lot of LED bulbs now have the higher resistance/load built into them to avoid the hyperflash problem.
    The LCM is not programmable to do what you want to do.
    As mentioned you either need to add resistors to each LED bulb or add an electronic flasher. Have have the flashers and detailed instructions available if needed.
    Apr 2008
    Springfield, MO
    Electronic flasher is the way to go !
    300A
    July 25,2002
    CD Player
    Mod: sunroof, SS hose even flow, triple gauge console, all led bulbs, SS brake lines
    2902 of 7839
    Flasher. Quick, simple.
    Jun 2015
    O'Hare IL
    Never heard of this electronic flasher. any more info or a link to check one out?
    Oct 2005
    West 'burbs Chicago
    Quote Originally Posted by GoldPanther View Post
    It's just the relay that controls the flash speed depending on load at the outputs. So if a bulb goes out it flashes fast to let you know.
    '21 F150 XLT 5.0 Sport
    '18 Chevy Malibu Redline
    '10 Harley Ultra Limited
    '08 Kawasaki ZX6R
    '03 Grand Marquis(sold)
    Jun 2015
    O'Hare IL
    Oh got it!
  1. Feed back tail lights not working but brake lights work
    By Gerry24 in forum Interior Electrical/Electronics
    Last Post: 12-28-2016, 07:02 PM
  2. 03 300b no park lights or tail lights
    By Wenke Racing in forum Interior Electrical/Electronics
    Last Post: 06-07-2015, 05:40 AM
  3. Tail Lights, Instrument Lights, Parking Lights NOT working
    By MercuryZephyrZ7 in forum Interior Electrical/Electronics
    Last Post: 01-27-2014, 12:56 PM
  4. Replies: 5
    Last Post: 06-08-2012, 07:43 PM
  5. Auto Meter Programmable Nexus Gauges
    Last Post: 03-20-2005, 08:28 AM
