Results 1 to 8 of 8
Thread: TA Performance girdle install instructions
    Aug 2004
    Fairfield, PA
    1 Drain rear end of gear oil and remove stock cover.
    2 Check all internal components for visible excessive wear, cracks, etc.
    3 If using the OPTIONAL Bearing Cap Stud Kit do the following:
    A. Remove original bolts holding the caps
    B. Install Studs, and torque studs in to the housing to 10ft/lbs (120
    in/lbs)
    C. Re-Install bearing caps and torque nuts to 60-75ft/lbs,
    4 Thoroughly clean the gasket surface of the housing.
    5 For best results we recommend running a bottoming tap
    through each bolt position. This will ensure that each bolt torques properly.
    6 Back Load Bolts out to clear the bearing caps ,but do not remove them, failing
    to do so may damage the cover or bearing caps.
    7 Install the 74 Performance Rear End Girdle with the supplied gasket, bolts
    and washers.
    8 Torque the mounting bolts to25ft/lb
    9 Screw the two load bolts in by hand until they make contact with the bearing
    caps.
    10 Torque the load bolts to 5 ft/lbs (60 in/lbs) MAXIMUM, excessive torque will
    result in distorted bearing caps. DO NOT OVER TORQUE THE LOAD BOLTS! Then snug
    the jamb nuts to lock the Load Bolt.
    11 Fill the rear end with gear oil using the provided fill hole on the TA Rear
    Cover, until fluid runs out of the factory fill hole on the side of the
    differential
    case.
    Off-Shore America
    Thank you, Mike, very helpful.
    Washington DC
    Thanks Mike, this is very helpfull information, because most people don't correctly torque the bolts and don't read the instructions. Following these guidelines are nessary because leaks will occur over time if you over torque the bolts.
    Connecticut
    I'm thinking that it would be a good idea to put some type of thread sealer on the threads of those center bolts, as well as on the jam nuts in order to prevent leakage. After all, there's a gasket keeping leaks out that's around the outside cover bolts, but there isn't any gasket that the center load bolts go into. right? What do you guys think?
    Jul 2003
    Virgo Super Cluster
    Two words born from direct experience: Friction Modifier
    Dave
    Connecticut
    Quote Originally Posted by Agent M79
    absolutely.
    Oct 2002
    Northern, Minnesota
    Billy, mine also leaked around the drain plug so a little thread tape their as well
    '03 Mercury Marauder Born 8/02 Adopted 9/02
    Vortech Supercharger w/ WA intercooler
    Race prepped block
    Cobra block
    CP Pistons
    Manley Forged H-Beam rods
    Billet oil pump gears
    Stud Girdle (Its pretty)
    MMDS Drive Shaft, Metco Contrl Arms, Metco Watts Link, X-CAL2
    Meziere Ele. Water pump
    Addco Rear sway bar, Addco front sway bar
    PI 3000 stall torque converter
    4:10 Ford Racing gears, Ford Racing Rear end Girdle
    Rear engine cooling kit
    A-piller gauges- boost and fuel pressure
    KVR custome Brake KIt - RED
    Cobra exhaust manifold with X-pipe
    Level II tranmission kit
    180 STAT.
    Art Carr deep Tranmission kit,Tranmission cooler
    KVR stainless steel brake lines
    High preformance Twin cobra fuel pump, Reinhart HP fuel Filter
    Bob White decals on side mirror, side windows & bumper inserts,
    Splash Gaurds, KB Dead Pedal
    Eaton Diff. Mos. 31 spline axles
    Connecticut
    Quote Originally Posted by Kelly
    Thanks for that info Kelly.....I've used some excellent thread sealer in the past for various applications made by ARP that I purchased from www.summitracing.com ("ARP thread sealer"). I've used it on gas line fittings, fuel pump fittings, engine coolant plugs, and rear end drain plugs. Works great.
  1. does anyone have instructions for dead pedal install,
    By MonsterD in forum Community Discussion
    Last Post: 06-14-2004, 04:51 AM
  2. Trilogy blower install at Alternative Auto Performance
    By Lidio in forum Trilogy Motorsports
    Last Post: 12-20-2003, 06:50 AM
  3. Alarm upgrade and Remote start install
    By nslatin in forum Shop Talk
    Last Post: 12-03-2003, 08:38 AM
  4. Welcome! Cole Performance!
    By Logan in forum News
    Last Post: 07-31-2003, 02:01 PM
