Results 1 to 7 of 7
Thread: Eibach Spring Install Instructions?
    Taxachusetts
    Hey Guys,
    Could someone give a detailed description as to how to remove and re-install new Eibach springs for the front? Or lead my to an already existing thread that describes front spring install? I am thinking of tackling this myself and just trying to get a feel as to how much time I am going to be spending in my driveway. I am a mechanically inclined person, so I am also wondering how long it will take a mechanically inclined person who is taking his time to make sure he does it right.
    Thanks guys!
    Marauderless....
    Your looking at 3-4 hrs. Pretty straight forward process for anyone mech. inclined.
    BTW removing the lower control arm isn't needed, its a tight fit but the spring/shock will fit out.
    Jul 2007
    Central Mass
    Tom, if you need a hand, you know a few of us local guys will help out,
    Rocknthehawk/Thunderbolt
    Quote Originally Posted by MrBluGruv View Post
    Those are my FAVORITE kind of people though. It's like, "the lone fact that I have to explain to you how wrong you are, is the very reason why trying to explain to you why you are wrong is pointless
    This thread may provide some insight on changing the springs once you get the coilover assembly out of the car.
    http://www.mercurymarauder.net/forum...ht=naake+front
    I haven't removed or reinstalled them in the car yet so that part I dunno about.
    Aug 2008
    Essex, ON, Canada
    a torch and large pry bar will be your friend. took me an hour and a half but i was working at my shop with all the tools i need.
    all you have to do is remove caliper/rotor, remove sway bar link, remove upper ball joint nut, strut top nuts and lower shock bolt. then pry down the lower control arm and pop the strut out. i had to heat the **** out of the upper balljoint nut to get it off but aside from that. it was smooth sailling.
    Apr 2005
    Frederick County, MD
    Modifications
    Click My Merc for more Pics!
    Taxachusetts
    I don't know if I am going to have the time or the patience for this haha... I am very busy with an EMT class right now so I may pay to have it done professionally and have it done at a place that can align... Kill two birds with one stone to carfixer's spec!
    Marauderless....
  1. air spring install?
    By cougar9150 in forum Shop Talk
    Last Post: 06-07-2009, 10:04 AM
  2. 4:10 gear install instructions
    By Go Mifuni in forum Shop Talk
    Last Post: 09-12-2007, 06:42 PM
  3. TA Performance girdle install instructions
    By Mike Poore in forum Shop Talk
    Last Post: 10-02-2004, 07:31 AM
  4. Pics of Eibach Spring installed in Photo Gallery
    By TAF in forum Community Discussion
    Last Post: 07-26-2003, 07:21 PM
