Results 1 to 15 of 29
Thread: Headers/Cat Delete/Tune
    Nov 2009
    Newport Beach, CA
    Since my Marauder now has a 63 Truck body sitting on it and is registered as a 1963, I do not need to run cats and am exempt from California smog laws. I bought a set of BBK long tubes for Mach 1 and want to build my own exhaust system. I have built exhaust sytems before and plan to use an X pipe and Magnaflow mufflers.
    Question. Location of the O2 sensors. There are bungs in the collectors of the headers which I expect will work just fine with the pre-cat oxygen sensors. What about the other pair located after the cats? Do I need to install bungs downstream a little?
    Question. I have a Diablo Predator. Will I need to install a new tune for the headers? What is the second set of sensors (after the first set of cats) for?
    thanks
    Karl
    Misquamicut, RI
    The second set monitors cat efficiency. They can be turned off in the tune. Since you don't need them, shut them down. You can either get eliminators, or run the original O2's in the bungs.
    300A
    born 08-27-02
    Adjusted air in and air out.
    400+ timeslips.
    Smithfield, Virginia
    How is it progressing? Pics?
    WIN WIN!~ Zack
    Quote Originally Posted by Paul T. Casey View Post
    You could also do the Gott's mod where you stack spark plug foulers in before the sensors (google it). This will simulate good Cat efficientcy even if you have NO cats like me.
    You can install the rear o2's any where after the cats. Mine are about 10"s after the crossmember so I could have room after the LT's for the electric cutouts.
    NEED MORE PICS!
    Nov 2009
    Newport Beach, CA
    Progressing Fine
    I have been driving the Marauder Truck for a month or so an sorting out rattles. It is a blast to drive and nobody can figure out what it is when I start it or open the hood.
    The interior is a work in process
    It tracks nice and handles great. It weighs about 3750 lbs
    Can't wait to get the headers, new exhaust and eventually the Cobra blower set up installed.
    I ENVY you! Looks badazz man, simply perfect.
    Nov 2009
    Newport Beach, CA
    second set of bungs
    What if I do not install a second set of bungs and unplug the cat sensors? Will I just get an engine light trouble code
    Nov 2009
    Newport Beach, CA
    her are a few more pics
    A few more pics
    Quote Originally Posted by MarauderPU View Post
    Yes you will. It would need to be turned off in the tune.
    or if you dont want to tune it just buy a set of MIL eliminators
    Nov 2009
    Newport Beach, CA
    Where do you get ML eliminators
    What does the ML eliminator do again? does it screw into the bung?
    iam assuming it is a resister or something of the like that physically tricks the computer to thinking the rear o2s are working like they should. its just plug and play, one end goes into the sensor wire and ther other goes into the harness on the car. i just got a set for my bronco from UPR, they were the cheapest i found. my problem was i put a catted bassani y pipe on the truck and the cat was so small the down stream o2 didnt see a great enough difference (basically thought there was no cat) so it would throw a p0420 code. i put the eliminator in and the code hasnt came back since
    Hiram, Georgia
    Underhood pics or you will be banned!
    Nov 2009
    Newport Beach, CA
    Underhood pics --Here you go
    The eng compartment will be cleaned up more when I install the blower with new valve covers
    man that thing looks right at home in there
  1. For Sale SCT Excalibrator DR Tune plus Race Gas tune $235 shipped
    By tetsu in forum Marauder-specific Parts for Sale
    Last Post: 10-12-2010, 05:32 AM
  2. Dyno Tune after headers
    By kmastl in forum Shop Talk
    Last Post: 07-17-2010, 04:35 AM
  3. Base tune or use Lidio's tune for break in?
    By dohc324ci in forum Community Discussion
    Last Post: 10-15-2009, 10:32 PM
  4. Cat delete
    By gnxtc2 in forum Exhaust
    Last Post: 05-07-2008, 10:22 PM
  5. Reinhart Tune vs. Alternative Automotive Tune ... differences?
    By Professor in forum Community Discussion
    Last Post: 06-17-2007, 11:11 AM
