Page 1 of 5 12345 LastLast
Results 1 to 15 of 71
Thread: Proper way to service your transmission
    Many people are either confused or have been given misinformation about the proper way to change transmission fluid and filters.
    Flushing will kill your transmission: Fact or Fiction?
    Joe Sixpack drives his car for years without ever giving a thought to the transmission until one day it starts making a funny noise or shifting strangely. Since it's about due for an oil change, he mentions the problem to the "technician" at Jiffy Lube, who sells him a "transmission flush". Three weeks later, the transmission croaks. Since the flush was the last (and only) thing done to it, OF COURSE that's what killed it, right? It couldn't possibly have been the years of neglect and abuse. The reality is that the transmission would have died when it did whether the flush had been done or not. If you wait until the transmission is acting up and the fluid is all burnt and nasty, you're living on borrowed time. Go ahead and change it...you may add some life to your transmission, or it may die anyway, but if it does die, it won't be BECAUSE you changed the fluid.
    Flush or Complete Fluid Exchange?
    Second, there is a lot of confusion surrounding the word "flush". Many people mistakenly believe that it means to somehow force fresh fluid backwards through the transmission, disturbing all kinds of sludge and what-not stuck in the filter and in the various passages and lodging it in important places of the innards. If that was even possible (which it isn't), there's no valid reason to do it this way.
    Every fluid exchange (and that is the preferred term) machine I've ever seen works passively, in more or less the same fashion: by using the transmission's own pump to push old fluid out into one end of a double-ended cylinder divided by a sealed piston. The other end of this cylinder contains fresh fluid. As the old fluid enters the cylinder, it pushes against the piston, which causes the fresh fluid to be pushed into the transmission in the same direction, and at the same pressure, as fluid flows when the transmission is operating normally. Here's an example. For those who may not be aware, this is the exact procedure recommended by Ford in the factory service manual.
    For times when a complete fluid exchange is not called for, such as during routine maintenance, a simple drain & fill will exchange approx 4 quarts of fluid, which is about 25% of the total capacity. This is sufficient to keep the fluid fresh when performed at intervals appropriate for the vehicle's operating conditions. Installing a $10 drain plug in the back side of the little "well" in the bottom of the pan makes the job as easy as draining the motor oil.
    The Filter: Less important than you think
    Now to filters. An automatic transmission is a sealed system, with no air intake to draw in contaminants and no combustion to create by-products, so the only thing the filter needs to catch is internal wear material. Most wear in an automatic transmission occurs during the first 10,000 miles of use from new, and it is this initial wear material that the filter is designed to catch. Changing the filter once, preferably at the 10-15,000-mile point (more or less) is a good idea, but from that point it is not necessary to change it again if the fluid is kept fresh. According to the factory service manual, it is not required to routinely change the filter unless the transmission is being repaired for a failure or is being serviced for fluid contamination.
    Jun 2007
    Whitehall, PA
    Nice write up. Installing a drain plug is essential. I drain and refill every other oil change.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    Quote Originally Posted by rf overlord View Post
    many people are either confused or have been given misinformation about the proper way to change transmission fluid and filters.
    flushing will kill your transmission: Fact or fiction?
    joe sixpack drives his car for years without ever giving a thought to the transmission until one day it starts making a funny noise or shifting strangely. Since it's about due for an oil change, he mentions the problem to the "technician" at jiffy lube, who sells him a "transmission flush". Three weeks later, the transmission croaks. Since the flush was the last (and only) thing done to it, of course that's what killed it, right? It couldn't possibly have been the years of neglect and abuse. The reality is that the transmission would have died when it did whether the flush had been done or not. If you wait until the transmission is acting up and the fluid is all burnt and nasty, you're living on borrowed time. Go ahead and change it...you may add some life to your transmission, or it may die anyway, but if it does die, it won't be because you changed the fluid.
    flush or complete fluid exchange?
    second, there is a lot of confusion surrounding the word "flush". Many people mistakenly believe that it means to somehow force fresh fluid backwards through the transmission, disturbing all kinds of sludge and what-not stuck in the filter and in the various passages and lodging it in important places of the innards. If that was even possible (which it isn't), there's no valid reason to do it this way.
    Every fluid exchange (and that is the preferred term) machine i've ever seen works passively, in more or less the same fashion: By using the transmission's own pump to push old fluid out into one end of a double-ended cylinder divided by a sealed piston. The other end of this cylinder contains fresh fluid. As the old fluid enters the cylinder, it pushes against the piston, which causes the fresh fluid to be pushed into the transmission in the same direction, and at the same pressure, as fluid flows when the transmission is operating normally. Here's an example. For those who may not be aware, this is the exact procedure recommended by ford in the factory service manual.
    the filter: Less important than you think
    now to filters. An automatic transmission is a sealed system, with no air intake to draw in contaminants and no combustion to create by-products, so the only thing the filter needs to catch is internal wear material. Most wear in an automatic transmission occurs during the first 10,000 miles of use from new, and it is this initial wear material that the filter is designed to catch. Changing the filter once, preferably at the 10-15,000-mile point (more or less) is a good idea, but from that point it is not necessary to change it again if the fluid is kept fresh. According to the factory service manual, it is not required to routinely change the filter unless the transmission is being repaired for a failure or is being serviced for fluid contamination.
    Exactly!!!
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Quebec
    Good information
    > have you hugged your Marauder today <
    Yeah the factory should have installed the drain plug,but I did do the pan drop around 20,000 miles and did the filter change. Should of put in the drain plug then. Next time I will.
    Oct 2011
    Westport, Ma
    I may be wrong on this but not to long Ago did or did not Motown marauder install one on his car or was that somthing diffrant I can't find his post with the pic he had .
    Oct 2010
    Wink
    Quote Originally Posted by Guittard22 View Post
    You mean this lil old pan
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Oct 2011
    Westport, Ma
    That looks super sweet how much that run you ? I am not sure if this was the pic I was thinking about or not. I was thinking you got a new silver case with pin for your back axle . Could that be what I was talking about !?!? There's a lot of information on this site to try to remember it all
    Oct 2010
    Oh you mean this one?
    ITS ALIVE !!!!!!!!
    Washington State
    "mag-hytec" 4r70w........google search
    Oct 2011
    Westport, Ma
    Yes I do looks super sweet
    Dec 2007
    Toronto, Ontario, Canada
    Doesn't the pan from a F-350 fit? (I thought I'd read that sometime).
    Where can one get one of these plugs? Are they vehicle specific? (I'm in Toronto, Canada; and don't know if I just walk into Napa or something like that).
    "Barry's" the name;
    Drums and Cars are my game
    "I smash the pedal; air and fuel go in; witchcraft happens; I go fast!"
    "No question is stupid, if you don't know the answer!"
    2004 / Black / 1981 of 3214.
    #184 of 509 in black out of 1214 total in all three colors with the moonroof option.
    Quote Originally Posted by Rockettman View Post
    Here you go.
    http://www.ebay.com/itm/Major-Brand-...6afeda&vxp=mtr
    Dec 2007
    ^^^ That guy only ships within the US.
    Thanks though. I guess they can't be that hard to find.
    "Barry's" the name;
    Search ebay.com for "transmission pan plug"
  1. Military Personel (Active Service and Prior Service)
    By Sir Charles in forum The Lounge
    Last Post: 03-04-2009, 09:49 PM
  2. A proper send off...
    By vonirkinshtine in forum The Lounge
    Last Post: 10-09-2008, 01:49 PM
  3. A proper send-off...
    By vonirkinshtine in forum Carolina Marauders
    Last Post: 10-07-2008, 06:26 PM
  4. Replies: 2
    Last Post: 12-10-2004, 10:10 AM
  5. Proper Mod Order
    By Agent M79 in forum Shop Talk
    Last Post: 11-25-2003, 05:44 PM
