Could I use an alternator off any crown vic? I would have to order Reman one and it would take 7 days, I dont want to wait. There's plenty of CV's at the yard...
No, marauder needs 4g, CV is different
Seven days? NAPA, Auto Zone, or Advance should have one, maybe not in stock but next day.
I definitely would not get an alternator from Auto zone , there parts are garbage.
STAY TUNED!!!!!!!!!!
I got one just sitting around how much do they normally go for?
If it's cheap and reliable it isn't fast
If it's cheap and fast it isn't reliable
If it's fast and reliable it isn't cheap
Have it rebuilt at a local shop.
Turn around is sometimes as short as 2 hours, and costs around 80-100bucks
This ^^
If you get a "new" alternator it will be Chinese junk likely to fail and leave you stranded. Put new bearings and brushes in your existing unit, or have an alternator shop do it for you. Re-use your existing internal regulator module from Ford, it is decent quality compared to the garbage at the parts stores.
Lifespeed
No, it won't work
dude Autozone, Advance, Orielys has in stock
Vin: 2MEHM75V63X615175
Build Date: 6/10/2002
Serial#: 995 of 7839
995 of 7093 Black
Accel coil on plugs/Autolite 104s/ K&N intake/Flowmaster 40s/Powdercoated goodys/
LED Grille scanner/BIGCARSFOREVER Dead pedal/SCT Tune/BBK Power Plus twin blade 65mm throttle body
Not to revive a dead thread but has anyone tried the 220 amp alternators that dbelectrical offers?
http://www.dbelectrical.com/p-9809-a...2003-2004.aspx
I seem to recall someone saying that they installed one of their products and they had an issue with the belt not fitting on the pulley or that their belt suicided on it ? Does this sound familiar to anyone?
I'm using a high output DB.
