This is SOLD, and the buyer showed up (took him forever to get here), it is going to an awesome home.
Ok, the time has come, I put 22 miles on this car last year, it'll probably see less this year. I am going to pass the torch. A member here or another forum will wind up with a super nice marauder.
I bought this car in late 07' IIRC, car was in Florida it's whole life, it has seen rain 3 times since I have owned it and gotten caught in it. Always garaged, always covered. It has never been wrecked, but has had paint work to the hood (obviously), it was panel painted and matches the car, the front license plate holder was painted body color, and I had paint work done around the filler door on the LR quarter(because I could see cast off from the metallic), yes, I am picky.
The car currently has 24,690 miles on it, that may change.....or not. I have a list of mods, but there are a ton of little things that are not listed, like all the CNC billet aluminum brackets for parts you can't see, and won't unless you disassemble the car. A lot was put into this car, and it shows, but, I am sure more could be done, nothing that can't be accomplished with more cubic dollars.
The car should be retuned, it got a smaller pulley, 3.00" that added 3lbs of boost for a total of 16, also a killer chiller was added at the time, as well as the accusump. The last tune was at Alternative Automotive, 521rwhp 526rwtq with 13lbs of boost on 93. As of 6/20/17, I have changed back to the original pulley as a buyer that was interested was concerned about getting a tune, so, as it sits, 521/526 are accurate numbers..
This is a real deal sale, not a feeler, I'm looking for 40k ($40,000)for the car, I have close to double that in it. Shipping is on the buyer, If you want me to deliver it, I can depending on location, I will need paid up front for the car and delivery prior to driving to your location. I may consider trades, if it' something of interest to me, maybe we can do a deal.
A couple of things, the seats that are in the car as it sits are from an 03', pockets in front. The front seats do not have the seat heaters installed, as I used the foam and covers from the 03' donor seats I had.
The car needs detailed, seriously.
More pics to follow......
2MHHM79V14X691479
Production sequence number is 3156 of 3213.
Color sequence number 970 of 983.
MM with moonroof, #358 of 365. This is out of 1213 made in all 3 colors.
Charcoal interior
Heated seats
Trunk organizer
Rear spoiler
Full size spare on non-polished wheel
Parts that have been changed out/added….
Stroker motor, 5.0 built at Lidio's shop
Trilogy Lysholm Twin Screw supercharger 13psi 521RWHP/526 tq .... street tune w/old pulley
LJI tensioner & idler pulley bridge
LJI stainless crossover tube
Cobra Engineering rear cooling mod
Accusump pre oiler
Thump Racing belt tensioner
Crower cams
42 Draft designs catch cans(pair) with XRP line & AN fittings
Frozen boost type 100 water to air intercooler
Auto Meter Mechanical oil & fuel pressure w/isolators
Killer Chiller
Autometer temp gauge for killer chiller
Line lock(s)
BC Automotive built transmission
Circle D triple disc converter
Dynotech driveshaft
Moser rear axles
External transmission cooler
Xcal II - un-locked
Stainless works long tube headers and high flow cats
Flowmaster mufflers
Delete tips (Stainless Specialties)
NAAKE double adjustable shocks rear
Heinous Motorsports rear control arms upper/lower
Addco sway bars, front/rear
Wilwood brakes front/rear
T/A performance differential cover
Widened rear wheels
PVD coating on wheels, i.e. chrome
floating center caps
Nitto 555 tires front 235/50/18
Mickey Thompson 305/45/18 on rear
carbon fiber air tube
PHP air box
SCT MAF
Tinted windows 38% - Formula One Ultimate
Infinity speakers front/rear REF6802CF 6X8 Speakers
Pioneer amp
Class Glass hood with quick latch pins
Custom badgless grill
rear godshead badge from Colex Customs
Godshead steering wheel center overlay from A3GR
SRP pedals, door sills, heel guard
Seats recovered with burgundy leather inserts with "Trilogy Motorsports" logo on seats
BigCarsForever dead pedal
Real Autometer gauges - wideband, boost, oil pressure, volts, trans temp, fuel pressure
OEM Ford chrome shifter trim bezel – button & collar.
Martyo fender emblems
Fuel bib
OEM Locking Ford gas cap
OEM Ford door edge guards, not generic, molded & coated, specific to MM/CV/GM
Proguard & custom bracket (no rear bumper sag)
Silverstar bulbs in front
HID's in fog lights
