Good evening folks....I finally got my motor rebuilt and looking for a dyno shop that doesn't charge my first born for a tune?
Welcome to the DARKSIDE...
2003 Black Mercury Marauder
Black and Chrome RPM 505 wheels staggered 18x8 and 18x9, Custom tune by ELD Performance, JLT cold air intake, FRPP 4:10 gears, PI 3000 Stall Torque converter, PHP intake spacer, Stainless Works Complete Exhaust, Eibach Pro Springs, Steeda underdrive pulleys, Custom Painted Black factory spoiler, 15% Tint front and rear , Kenwood Excelon 6x8 Front and 6x9 rear Speakers, Pioneer 600w 4 channel amp, Zack and Mack Control arms, Addco Front and Rear Sway bars
Best run: 13.75 @ 99.6 sec on 4 May 07
+1 on Mo's!
I live in Maryland. Looking for a local shop.
What's up brother! Long time no hear! do you have any special mods or just motor? Just motor then Mo can send you a tune. If you want a dyno tune for mods I suggest you come visit my tuner in DE Performance Evolution in Smyrna. I'll by you lunch while you wait.
3.35 L 4X4
-AND-
SLAYER1
Mo will also remote tune over the phone or if it's easy for you, then rent a dyno if need be.
I always get the cheapest tune to go with the cheapest everything else that way when it breaks it's cheapest to be fixed.
MO's is worth the drive, but it's your car.
I'll be driving down to Mo's sometime in the future to get 4.10 gears and redynoed. Its a 19 hour drive for me but I want a place I can trust.
I trailered mine 11 hours each way from Chicago!
My route was over 1,565 miles to get it done right & with some sight seeing in Atlanta.
I'll be back there a 6th time after Louisville 2018.
Trilogy With Comp Cams Stage 3 Sound's
https://www.youtube.com/watch?v=GUIRJ1zGhSA
https://www.youtube.com/watch?v=AAUWZ9f8gXw
https://www.youtube.com/watch?v=mrPUl529gog
https://www.youtube.com/watch?v=KvfRjhiGT4w N/A Sound
Dyno By "Mo's Speed Shop",Dallas,Georgia https://www.youtube.com/watch?v=VqxN3FjWd6s
445 RW/HP @ 398 Torque S/C
Jeff Doing a Traditional Burn Out At "Mo's Speed Shop" https://www.youtube.com/watch?v=nCyKuC5heAI
So Far Best Run12.84 @106 MPH https://www.youtube.com/watch?v=dlA-0vB0HwU
Big "Thanks" To Gerald,Derek,Bill & Harrison
"Thanks" Martyo & Jeff
#6486 of 11,052 03 300B In Black
On my way back from C-School in Norfolk Va, I detoured to Mo's for a tune. Best choice I ever made regarding my Vic's performance. Your about 10 hours from him. Road trip. You won't be disappointed.
2003 Mercury Marauder- Stock with 223k miles.
2000 Crown Victoria P73. Deep Wedge Wood Blue.
SW longtube headers and high flow cats, magnaflow mufflers, 3.55 gears w/track lock, 70mm Aviator TB, PnP factory plenum, ADTR intake tube, 87 octaine tune by MO. Bilstein HD shocks, Mecto Rear control arms w/ watts link, Addco custom order 1.5 inch front sway bar (38mm), 1.25 inch rear bar 31.75mm (only 11 made).
The people have spoken.
Holler at me if I can help.
