Results 1 to 15 of 15
Thread: Cost of oil filter adapter..?
    Jan 2005
    Just South of Memphis, TN
    Anyone got an idea what the cost is for the oil filter adapter...?
    I believe it's the piece that connects the oil filter to the engine...
    I had an oil leak and my local ford dealer replaced it for only $646.00..
    ANOTHER QUESTION: they said my oil pan has SEEPAGE... Is this OK????
    Thanks folks...
    Architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    you was robbed, what's the breakdown of services on your bill?
    Blog Entries
    2
    $300.00 per hour
    $125.00 Enviro Fee
    $67.00 parts.
    That oil leak was ONLY a $9.00 gasket. The housing doesn't leak every time, you should have ran this repair past us, or asked on the marauder Facebook page
    Sucks
    Labor was probably a major part of the bill. When I did mine I had to drain coolant and oil, then pull off PS pump just to get to the part for replacement. Then after replacing the part you need new coolant, oil, filter.
    Hopefully they burped the cooling system properly or you're fixin' to have overheating problems.
    Seepage, leakage, tomayto, tomahto.
    Apr 2010
    South Florida
    I had to replace the filter adapter because it was cracked where the pressure switch was located.
    Mine had a hairline crack there as well, caused a occasional drip, tig welded mine, no more drip.
    Trilogy # 192 / T.S. 0012
    Sep 2005
    APPLE VALLEY,CA
    Dealer charged me more than that in 2009.
    Jan 2005
    Next Time...
    I promise NEXT TIME... I will ask ya'll before I go in...
    almost everything that was posted was correct...
    I did discover that an old acquaintance from another dealership has joined this dealership...so maybe I'll have a bit more help from now on...
    As always...THANKS SO MUCH FOR TIME AND HELP...
    30% Window Tint
    Rear Spoiler
    Jan 2005
    Recap of invoice
    Technician 389.00
    Gasket 18.00
    oil filter adapter 186.00
    oil 3.95
    oil pressure switch assembly 5.67
    Rough total $600.00 (no tax included)
    Thanks, Architect
    30% Window Tint
    Rear Spoiler
    Sep 2008
    USA
    $300.00 per hour
    $125.00 Enviro Fee
    $67.00 parts.
    That is the most expensive labor I have ever seen.
    Ex Panther Owner
    Sep 2005
    APPLE VALLEY,CA
    People get confused by this.
    There is a oil filter adapter that leaks. Adapter - Ford (9W7Z-6881-E)
    https://www.ebay.com/itm/FORD-OEM-En...-/191297720020 (Picture #19)
    The there is the Oil Cooler Gasket, Adapter Seal, Support Gasket, Gasket
    for the oil cooler that also leaks. https://www.ebay.com/itm/FORD-OEM-En...FZ4pg3&vxp=mtr
    (picture # 3)
    The first repair costs way more in labor to fix. I believe that is the part repaired in this original post.
    (picture # 3)
    I too believe it's #19. The engine oil filter adapter housing, that is cooled with coolant....
    All that other stuff you posted, I've never seen any of that stuff under the hood of my marauders... where is that exactly?
    Aug 2014
    Fort Benning, GA
    Ford quoted me $375 here in GA; mines leaking, too.
    Kinda easy replace.
    '03 300A Marauder, 107K miles, flowmaster 40 series mufflers, 2nd cats deleted, HID 6000K foglights, SilverStar Ultra's headlights, goodyear gatorback belt, K&N FIPK, K&N drycharger, SS inserts, spoiler, MSD COP's, Nitto Motivo's.
    Quote Originally Posted by jmsa540 View Post
    Kinda easy replace.
    It's a big mess, but only a hours worth of work. Felpro gasket is avail at the parts store
    I did my car, no more leak
  1. For Sale 03 MM Oil filter adapter, dipstick and more
    By VA-Mach1 in forum Marauder-specific Parts for Sale
    Last Post: 05-24-2016, 04:04 PM
  2. For Sale Oil Filter Housing / Adapter
    By Blaine B. in forum Marauder-specific Parts for Sale
    Last Post: 01-14-2015, 07:48 AM
  3. Oil Filter Adapter Gasket
    By TiTo35 in forum Shop Talk
    Last Post: 06-16-2012, 09:11 PM
  4. Ever have a leaky oil filter adapter?
    By Capt Jake in forum Shop Talk
    Last Post: 02-07-2012, 10:20 AM
  5. Oil Filter Adapter Gasket
    By yryr999 in forum Shop Talk
    Last Post: 10-13-2011, 04:12 PM
