Results 1 to 15 of 27
Thread: Dead fuel pump...?
    Dead fuel pump...?
    OK....
    So I pulled the split block 5.0 DOHC last Spring.
    Had my OEM short block rebuilt and got everything back in the Marauder.
    Now, when I 'Key ON' or crank....there is no fuel pressure.
    - Cannot hear the fuel pump run to build pressure.
    - Checked Fuel pump relay and fuse....Both good.
    - Trunk mounted inertia switch is not tripped.
    Can a fuel pump just die from sitting for a year+?? (Marauder was stored indoors/heated garage)
    Any other things I should check?....
    When I get it running again....who wants to buy a super clean 18,000 mile Marauder??
    (Fusion Sport is quicker, smoother and knocks down 25+ MPG all day long.)
    It's possible but not likely that the pump quit. Something electrical is my guess. Not much help but just hang in there.
    Jul 2010
    Guntersville Al.
    This is possible. My sons will buy cars they find sitting in back yards, and fields, that have been sitting anywhere from 6 months to several years. One of the first things they check is the fuel pump. More often then you think the pump will be bad. Make sure you have power to the pump. If you do and it's not on, then it's time for a pump.
    It was an honor to have
    my ASS kicked by you!
    Rest In Peace!
    Paul T. Casey
    Nov 2008
    North of the Border
    Don't forget the FPDM.
    And the answer is.....
    Fuel pump was 'stuck'!
    - Disconnected the fuel pump wiring harness right above the rear axle.
    - Applied 12VDC directly to pump from a spare car battery.
    - Pump would make a very slight click then nothing.
    - Reversed the 12VDC leads to try and spin the pump backwards....
    - Fuel pump runs!
    - Put the leads back to the pump correctly....
    - Fuel pump runs!
    - Reconnect fuel pump wiring harness and turn ignition key on...
    - Fuel pump runs and pumps gas like it should.
    Saved myself a lot of swearing and cut knuckles trying to get the fuel pump hat out of the tank.
    Now I've got to siphon the stale gas out of the tank and put some fresh 93 octane in.
    Maybe she'll fire up for the first time in 2+ years!
    May 2009
    Moreau Island
    How much gas was in the tank? Had a similar issue with the SB a few years ago. I had about a 1/4 of a tank and the car sat for a few months. When I tried to start it, nothing and it had worked just fine when it was parked. Bought a fuel pump, but on a lark I poured 5 gallons of 93 into the tank. Car started right up. I bring the pump with me on long trips just in case, but it's been a few years with no issues. Long of the short, if you are storing the car for more than a week or two fill the gas tank.
    Yep....was about 1/4 -> 1/3 tank of gas.
    Only problem was getting it to a gas station once the engine expired....
    Oct 2003
    Beaufort, SC
    Disconnect Fuel Filter and run a hose from tank connection to a container.....turn ignition on and let the lazy Fuel Pump work for ya Joe!!
    Great minds think alike!
    I tried that but the fuel pump will only run for @ 5 seconds before it shuts off. Then you have to 'key Off - key On' cycle it each time.
    Oct 2003
    Beaufort, SC
    FPDM must think the fuel line is broken and shuts it down....wonder if you can bypass it somehow??
    How's the old gas smell......bad or OK??
    Aug 2007
    Medina, Ohio
    pump
    Same exact scenario here. We pulled the pump, and the sock was deteriorated. The pump was bad. Siphoned the turpentine smelling gas, put in new gas, and fired right off. That was two weeks ago. Running great now. We always put in fuel stabilizer, but it is not good forever. My original 96 Impala SS was filled with Amoco premium in 97 when I parked it. Amoco's premium used to be known by nickname of "white gas". Fuel still smells new and runs great. All the additives today have hurt some of the fuels.
    Actually the 'old' gas didn't smell bad...nor like paint varnish.
    Got about 6+ gallons out of the tank and poured it into my 3.sl0w Ranger.
    That cast iron boat anchor-of-an-engine will burn anything!
    Got 7 gallons of fresh 93 octane and I'll disconnect the fuel feed at the intake manifold....
    then purge any leftover/old gas, reconnect the fuel line fitting and fire her up this weekend.
    Feb 2012
    harrison twp,mi
    I didn't have a way of pulling the line off so I just unscrewed the shrader valve and used a hose and a hose clamp. Good luck I hope it goes smooth.
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Oct 2003
    Beaufort, SC
    Sounds like you'll be OK Joe!!
    Good Luck!!
    " IT's ALIVE!!! "
    Today, I fired up the Marauder with my freshly rebuilt OEM 4.6L short block.
    Warmed her up, broke her in and everything was working properly.
    She's still got the ported heads, extrude honed intake and Crower cams, plus the headers/exhaust..... and she runs like a scalded cat!
    I haven't driven the car in 3 years....but Ohhhh what a joy!
    Sounds awesome....haven't heard a V8 howl like that in wayyy too long.
    Maybe I won't sell her after all.
  1. Replies: 6
    Last Post: 09-22-2015, 09:36 PM
  2. Dead Fuel Pump Troubleshooting Guide
    By Phrog_gunner in forum Shop Talk
    Last Post: 04-02-2014, 06:25 PM
  3. Maxflow® Fuel Pump Booster or KB boost a pump
    Last Post: 01-14-2013, 09:41 PM
  4. Replies: 13
    Last Post: 07-08-2008, 05:41 AM
  5. Replies: 47
    Last Post: 03-13-2008, 05:59 AM
